Author Topic: Juddering  (Read 3548 times)
megaomega123
Juddering
« on: 16 September 2009, 19:36:45 »
Car has started to judder when pulling off in 1st gear only. It doesn't happen until the car is nice and hot.
Handbrake was over adjusted but has now been slackened a bit. Had pattern cat on it which was ill fitting, changed that today for 2nd hand gm one. There was a lot of water came out of the old one. Just some history there in case of any links to the juddering.
Re: Juddering
« Reply #1 on: 16 September 2009, 20:00:10 »
Clutch ? :-/
megaomega123
Re: Juddering
« Reply #2 on: 16 September 2009, 20:02:06 »
Clutch ? :-/
But why only when pulling off in 1st when warmed up? I thought clutch would affect more gears and at all times.
essex boy
Re: Juddering
« Reply #3 on: 16 September 2009, 20:15:04 »
gear box mount you would not notice it when going threw the gears cause your all ready moving but i could be wrong
essex boy
Re: Juddering
« Reply #4 on: 16 September 2009, 20:17:16 »
ok bin that i have just seen when warmed up contamainted clutch when warm would judder
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Juddering
« Reply #5 on: 16 September 2009, 20:19:20 »
Is it an auto or manual gearbox  :question
It maybe  low oil in the gearbox if its an auto, always a good place to start   :y
megaomega123
Re: Juddering
« Reply #6 on: 16 September 2009, 20:24:06 »
It is manual.
Re: Juddering
« Reply #7 on: 16 September 2009, 20:45:32 »
I popped a new clutch in this car shortly before you had it. It had a complete kit - ferrodo. Clutch plate, pressure plate, and thrust bearing - so it's unlikely it's had that much wear. It was all pretty clean back there at the time.
Check the mounts too.
Have you had any coolant leaks near the back of the engine?
megaomega123
Re: Juddering
« Reply #8 on: 16 September 2009, 20:54:10 »
I did think that was the case  :y No coolant leaks and no oil leaks or loss. I have a run to do tomorrow so I can see if the new cat makes any difference :question
Re: Juddering
« Reply #9 on: 16 September 2009, 20:56:34 »
I too would check engine and gearbox mounts, propshaft UJs and donut coupling, centre bearing.
Needing to be hot does make me think contamination of clutch surfaces though. Any leaks evident around the bell housing?
Could be the DMF on its' way out, of course. Or the spigot bearing.
Re: Juddering
« Reply #10 on: 17 September 2009, 00:21:59 »
while I agree with the logic - it was all very sound when inspected, not very long ago...  :-/
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
Re: Juddering
« Reply #11 on: 17 September 2009, 05:17:49 »
if it happens for the first 0-10-15mph and if you hold it at the speed it does it, it stops as with no strain/acceleration then it goes, could be propshaft centre support, that sound/feeling comes from behind the front seats, but cant explain why yours only does it when warm :-/ but saying that i dont remember mine doing it when i left the house in the morning. a passenger in the back(middle) could feel it under his feet when it did it.
« Last Edit: 17 September 2009, 05:26:01 by lovelectricity »
oh bugger, i thought that was a bit of wind!!!
Burtle
Re: Juddering
« Reply #12 on: 17 September 2009, 12:46:55 »
The spigot bearing would make one hell of a lot of noise every time you press the clutch if it fails. It did on mine, though intetrestingly didn't make it judder!
Cheers
Nath
capoMV6
Re: Juddering
« Reply #13 on: 18 September 2009, 09:22:42 »
Checking the engine mounts is a good place to start.
megaomega123
Re: Juddering
« Reply #14 on: 18 September 2009, 10:41:21 »
Ok Had a few runs now and it is very intermittent. I also get a "spinning squeak" when the clutch is depressed. Again this is intermittent and not very loud and only seems to happen when in 2nd and then depress clutch. I'll try and get a lot of the suggested items checked today and report back.
Thanks
