Author Topic: Classic Omega problem, please help!  (Read 3840 times)
katiecuppa
  • Axminster, Devon
« on: 19 September 2009, 18:29:00 »
Hi all. I am a woman in distress, I am in Devon. No that is not the problem, the problem is my '97 Omega estate 2.5 v6. It is unwell. It has the common problem of dying once the engine is hot. It restarts after the engine has cooled, but prior to stalling the temp guage drops to 0 and the rev counter bounces all over the place. The engine will restart once cold. The previous owner changed the crank and cam sensors, the HT  leads. The RAC plugged it in and the fault code was 31. Any ideas!!! I dearly want to drive the car for more than 10 minutes. I await your help with great anticipation. ;)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Classic Omega problem, please help!
« Reply #1 on: 19 September 2009, 18:55:19 »
A bit of a long shot here, but I've come across this before, and it was purely down to a duff main earth lead.
To eliminate/confirm, just get a jump-lead and connect one end firmly to, say, a manifold stud/nut, then firmly connect the other end to the negative terminal on the battery. See what happens.
« Last Edit: 19 September 2009, 19:32:04 by Reliance505 »
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #2 on: 19 September 2009, 21:30:43 »
I'm no expert on the V6, but isn't code 31 crank sensor?
I like red cars
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #3 on: 19 September 2009, 21:33:26 »
Nope thats code 19
code 31 is no rpm, normal without engine running.
He who brakes Looses
To old to die young
« Reply #4 on: 19 September 2009, 21:33:46 »
No, 19 is.
31 is normal, means no RPM signal (codes were run with engine off)
First things first, clean the ICV!
« Reply #5 on: 19 September 2009, 21:34:28 »
 ;D ;D ;D Myself and Rob posted that at exactly the same second
« Reply #6 on: 19 September 2009, 21:37:29 »
Deleted mine :D :D :D
« Reply #7 on: 19 September 2009, 21:41:01 »
Ah ok, I was scrolling back through this thinking i had gone mad!!  ;D
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #8 on: 19 September 2009, 22:03:09 »
Hi sounds like a ecu fault, is it the ecu with the heat switch on top says 85c-95c, now to be honest i dont know were u can get these from but u can remove it, but allso the crank sensor makes this fault turns off the engine dead, and when its cool'd down its back to being ok try paper clip test, :y
« Reply #9 on: 20 September 2009, 02:19:40 »
???? Shes quoted a fault code of 31 above.
Try the common fix first - clean, lube and reseat ICV.
Also check MAF connector for tightness.
« Last Edit: 20 September 2009, 02:20:12 by dbug »
« Reply #10 on: 20 September 2009, 10:26:59 »
first things first, clean the ICV!
katiecuppa
  • Axminster, Devon
« Reply #11 on: 20 September 2009, 12:47:37 »
Hi Guys, I have tried the paper clip test and the codes are now 19,73 and 74. Bloody RAC my cancellation of membership is in the post haha. Firstly I think the crankshaft sensor has to go. I replaced the MAF, it is either a dud or wiring problem. Here we go again. Thanks all for your advice so far. :)
« Reply #12 on: 20 September 2009, 12:51:35 »
Code 19 is the crank sensor so I would replace that first with a genuine Vauxhall one. I bet the other codes clear when you've replaced the crank sensor ;)
« Reply #13 on: 20 September 2009, 13:32:21 »
As above ^^^^^^^^^^ code 19 crank sensor - replace with genuine Vx  :y
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #14 on: 20 September 2009, 18:38:35 »
Re code 19 crank sensor ,is the way to go .Dont cancell RAC yet ,never know  you may need a wheel changed  . : :y
