Author Topic: car shaking advice needed  (Read 2729 times)
mathewst
  • Split, Croatia
    • v40
« on: 23 September 2009, 16:42:33 »
During highway driving everything is ok at 130 km/h but around 140 to 145 car starts to shake.
Can anyone write down the possible reasons for this in some order how is best to check them.
Thanks.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: car shaking advice needed
« Reply #1 on: 23 September 2009, 16:55:27 »
maybe the engine mountings, apart from that could be springs or shocks, even the propshaft. there are lots of stuff on the car that can make it shake rattle and even roll but you dont wont the last one :y :y
« Last Edit: 23 September 2009, 16:55:55 by Russell_Hill »
El Diablo
« Reply #2 on: 23 September 2009, 17:20:15 »
your wheels need re-balancing mate.
ali
  • hertfordshire
« Reply #3 on: 23 September 2009, 18:03:31 »
I would go for the wheel balancing first :y have you clipped a kerb  :-?
JayMV6
  • Reading
« Reply #4 on: 23 September 2009, 20:15:08 »
Mine does the same some bloke gave me qoute £15 for all 4 set to zero id try this first especially as the other possibilites are more dosh 8-)
« Reply #5 on: 23 September 2009, 22:08:27 »
as stated above, wheel and tire balance problem..
but try some shops who makes the balance with wheels on car.. and if more than 15-20 gr is required either the wheel is buckled or the tire needs turning (around the wheel) ..
« Last Edit: 23 September 2009, 22:10:06 by cem_devecioglu »
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 23 September 2009, 22:45:14 »
Well I did have the suspension balanced after I bought new tyres. Only the morons balanced the suspension first and then replaced the front and back wheels  (just replaced cause new tyres were alrealdy indtaled on front wheels, now they're on the back)
Car seems to shake from the back, sprigs seem ok and so do the shocks
« Reply #7 on: 23 September 2009, 23:22:38 »
140-145 km/h requires a good balance.. I suffered a similiar problem in the past.. and it was found to be slightly buckled wheel.. But this was found after changing with another wheel as we were thinking it was the tire.. :(
try an adviced shop in your area.. :-/
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 23 September 2009, 23:31:58 »
It does sound like you have thrown a weight, you could try putting the spare on to compare.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #9 on: 24 September 2009, 00:05:19 »
If the issue is down to wheel balance then vibration felt through the steering wheel around 55mph means the front wheels are out of balance.
If the vibration happens around 65mph and above and is felt through the seat and not through the steering wheel then it is the rear wheels.
mathewst
  • Split, Croatia
    • v40
« Reply #10 on: 24 September 2009, 08:00:39 »
Unfortunately Agemo can't put a spare on cause it is smaller wheel (15), and definitely dont want to drive 145 km/h with diferent size wheels.
Turk know about this what you have written, shaking is felt through the seat not the steering wheel so it is coming from the back
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #11 on: 24 September 2009, 08:56:47 »
Rears needing balanced would be my bet  :y
« Reply #12 on: 24 September 2009, 09:04:39 »
agreed :y
KillerWatt
« Reply #13 on: 24 September 2009, 10:18:31 »
Just to throw something else in to the mix of suggestions...our MIG used to shake the occupants from side to side in their seats at certain speeds.
Problem cured after new wishbones, droplinks, & front shocks fitted.
mathewst
  • Split, Croatia
    • v40
« Reply #14 on: 24 September 2009, 10:21:07 »
Thanks KillerWatt but shaking seems to come from the back, so I guess everything in the fron is ok
