Author Topic: Removing estate rear seat left and right headrests  (Read 1471 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« on: 23 September 2009, 12:36:10 »
Can the rear left and right headrests on an estate be removed.  I'm aware that they fold down for when you want to put the seat flat, but can they actually be taken out?
BTW this is on a facelift if that makes any difference.
« Last Edit: 23 September 2009, 12:45:01 by mrhagon »
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Estate rear left and right headrests
« Reply #1 on: 23 September 2009, 12:39:36 »
yes they can there is a clip on the arms plastic push in and pull off :y :y :y
Mr Hagon
  • South West London
« Reply #2 on: 23 September 2009, 12:44:08 »
Are you talking about the front driver and passenger headrests as I know there's a button to press that means you can pull them out.
« Reply #3 on: 23 September 2009, 14:55:00 »
I always thought the rears only folded down and didn't come out.
rustym95
Re: Removing estate rear seat left and right headrests
« Reply #4 on: 23 September 2009, 14:55:37 »
they should be the same on the back if not they have a clip u need to push in. just go and check. :y :y yep there are on mine push in and pull up, or they can have a cover on them that u will need to pop it up to get to it. it is atatched to the bottom part.:y :y
« Last Edit: 23 September 2009, 15:00:04 by Russell_Hill »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 23 September 2009, 15:28:50 »
On a FL rears they dont come off, only fold down by pushing the center button. There is a way of getting the top bit off iirc but your then left with the two metal prongs sticking out of the actual back seat.
Would think if you started to take the back panel off the seat you could remove the whole lever bit. If that helps.
Chris  :y
ali
  • hertfordshire
« Reply #6 on: 23 September 2009, 17:58:06 »
Ive got both types, if its the push button ones they can be real stiff to get off :-? but becareful not to get too carried away or you will end up in the foot well :o like I did ;D ;D ;D ;D ;D
Mr Hagon
  • South West London
« Reply #7 on: 24 September 2009, 12:21:47 »
Cheers for the responses.  I will have a nose around and see if I can get the headrest off somehow.
