Author Topic: electronic climate control  (Read 1377 times)
wurlitzer53
  • newport south wales
« on: 24 September 2009, 13:13:18 »
Hello all. The blowers on my 2001 omega 2.2cd Facelift have suddenly stopped working, checked the fuses,seem ok , tried pressing "A"& "OFF" & can hear the servo's working but still no blowers!! Can anyone help me please as I've no idea what to do??????
mathewst
  • Split, Croatia
    • v40
Re: electronic climate control
« Reply #1 on: 24 September 2009, 13:35:38 »
Did you check both fuses and relays?
Try to unplug those for climate control and plug them back in
wurlitzer53
« Reply #2 on: 24 September 2009, 13:46:15 »
Hi ,
I did'nt check the relay cos I don't know which one it is.
« Reply #3 on: 24 September 2009, 13:47:38 »
Hi ,
This might help .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
wurlitzer53
« Reply #4 on: 24 September 2009, 13:52:54 »
Thanks for that I'll check it out.
wurlitzer53
« Reply #5 on: 24 September 2009, 14:32:25 »
I've just finished pulling all the relays out and back in ,still no blowers????????????
« Reply #6 on: 24 September 2009, 14:39:12 »
Get someone to switch the CC on and off while you GENTLY rest your fingures on the relays, you should feel them activate, if they don't it could be a failed relay.
This is NOT a gauranteed fix, as you need to know exactly which relay does what, but it might help.
wurlitzer53
« Reply #7 on: 24 September 2009, 14:57:05 »
Thanks, I'll try.
