Author Topic: Its dripping  (Read 6434 times)
Monza
  • Bungay, Suffolk
Its dripping
« on: 24 September 2009, 20:11:29 »
Over the last few days when I park up, I come out to find a watery like red stain on the road, its dripping down from the front drivers side, off the front valance on my MV6, looks like power steering fluid, but the levels are fine. I can see most of it under the air box by the air con pipes and a bit splatered on the side of the airbox :-?. Any ideas?
Past Drives: 16 Monzas, 1 x VW W8 4motion, 1 lotus Carlton, 1 Carlton GSI, 1 Omega Evolution, 1 Vectra 2.5V6, 2 Omega MV6s, 4 Cavaliers plus 131 others over the years!!
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Its dripping
« Reply #1 on: 24 September 2009, 20:34:31 »
Have you been driving in Autralia?/  could be a leek in the cooler.
Monza
  • Bungay, Suffolk
Re: Its dripping
« Reply #2 on: 24 September 2009, 20:35:29 »
oil cooler?
rustym95
Re: Its dripping
« Reply #3 on: 24 September 2009, 20:38:20 »
oil cooler?
yeah the pipes go round there, might be that your pipe is rusting, try running the engine hard and see if any thing is coming out any were, cos it naybe it did it ages ago.
Monza
  • Bungay, Suffolk
Re: Its dripping
« Reply #4 on: 24 September 2009, 20:41:09 »
What do you mean, did it ages ago?
rustym95
Re: Its dripping
« Reply #5 on: 24 September 2009, 20:44:00 »
pipes rust they can take there time to bust little pin prick in the metal, not like water ones they go thay go. should be able to see it or feel it.
Welung666
Re: Its dripping
« Reply #6 on: 24 September 2009, 20:46:20 »
Is the puddle oily or watery?
Re: Its dripping
« Reply #7 on: 24 September 2009, 20:47:09 »
If your MV6 is an auto, it could be gearbox oil. There are pipes from the gearbox to the gearbox oil cooler which is located in the driverside of the radiator. I would check the banjo bolts which locate the pipes into the radiator
    • 530D M Sport, 330i Coupe
Re: Its dripping
« Reply #8 on: 24 September 2009, 20:49:01 »
Power steering pipes run infront of the radiator (to cool the fluid), if they leak it would drip onto the lower section of the bumper where it goes under the car.
Also, if you are using Vx coolant it is generally a red / orange colour.
Welung666
Re: Its dripping
« Reply #9 on: 24 September 2009, 20:50:27 »
Hence my question ;)
Monza
  • Bungay, Suffolk
Re: Its dripping
« Reply #10 on: 24 September 2009, 20:56:05 »
Just had a look, it seems the pipe comeing down from the radiator and heading under the air box is corroded at the pioint where it goes into rubber section, its then collecting under what I think are A/C hoses that sit in a gully sectionunder the air box. Still dont know if coolant or power steeting or.... using Vx fluids by the way. Its more oily than water, its stains the road, but is red when you wipe it up with a white cloth? Need to do 300 miles tomorrow (mainly M25 traffic), just trying to work out if I can :D
Re: Its dripping
« Reply #11 on: 24 September 2009, 21:07:28 »
My money is still on gearbox oil
Re: Its dripping
« Reply #12 on: 24 September 2009, 21:09:22 »
Sounds like ATF, drivers side is where the cooler sits. Either the pipes that run too and from the box have corroded (most likely) or the rad's oil cooler has failed.
I'd check the ATF level in the gear box
Re: Its dripping
« Reply #13 on: 24 September 2009, 21:10:56 »
Taste the fluid!
Monza
  • Bungay, Suffolk
Re: Its dripping
« Reply #14 on: 24 September 2009, 21:35:56 »
No taste really!
