Pages: 1 2 [3]  All   Go Down
Author Topic: Wishbone bushes  (Read 5102 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Wishbone bushes
« Reply #30 on: 23 September 2009, 23:49:30 »
Ordered poly ones - no fitting costs and quicker to arrive
...and the last time you'll replace a wishbone due to a failed rubber bush. :y
Ok, I've had a ball joint fail, but that's one in eight years. I've had to replace the wishbones due to front bush failure at least 4 times. And yes, they were always re-torqued correctly.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Wishbone bushes
« Reply #31 on: 23 September 2009, 23:57:25 »
One alternative and potentially more cost effective approach would be to fit Lemforder wishbones or bushes. I understand that Lemforder are the OEM for Vauxhall/Opel for these parts. The difference is that I paid £60 a piece (incl VAT) in March '98 from AutoVaux. More expensive than a pattern part from Buy parts By, but a third of the Vx price even with TC iirc. You pay your money and take your chance but half the price and 6 months life strikes me as a poor value for money in anyones book. The Lemforder online catalogue is here http://www.zf-trading.co.uk/uk_lem_en
For your '98 car ?  :o
v6coop
  • Nottingham
Re: Wishbone bushes
« Reply #32 on: 24 September 2009, 19:33:58 »
For your '98 car ?
oops. Living in the past I'm afraid. Should have read (20)08. Sorry.  :-[. I still maintain the same sentiment though.
Martin_1962
Re: Wishbone bushes
« Reply #33 on: 26 September 2009, 12:23:22 »
I have removed the rubber bit and the metal bit, but how much do I remove of the outsides, just the frame around the rubber or the next bit as well?
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Wishbone bushes
« Reply #34 on: 26 September 2009, 12:59:08 »
Hacksaw.  :y
Remove the blade, slide it into the bush housing then re-attach to saw with the teeth facing down (if still on car. If W/bones off car, use as normal). When you've cut through the metal sleeve the blade will probably become hard to move. This is due to it becoming pinched in between the now cut ends.
Prise one end of the sleeve over the other and it should slide out easily.
« Last Edit: 26 September 2009, 13:00:43 by Turk »
Martin_1962
Re: Wishbone bushes
« Reply #35 on: 26 September 2009, 13:00:41 »
I have removed the metal frame holding the rubber, but it was how much not how.
Do I remove the next sleeve or is that part of the wishbone?
Thanks
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Wishbone bushes
« Reply #36 on: 26 September 2009, 13:06:28 »
When I did mine, one bush had two metal sleves, the other had just the one.
Offer up the poly-bush. It should slide in with very little resistance. There should be no need to compress the polybush. If it doesn't slide in easily then there's another sleeve to come out.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Wishbone bushes
« Reply #37 on: 26 September 2009, 13:33:37 »
The type with two metal sleeves (with bonded rubber in between), are "Metalastik" jobbies.
I've successfully used an air hacksaw to remove them in the past from leaf springs.
« Last Edit: 26 September 2009, 13:36:07 by Reliance505 »
Pages: 1 2 [3]  All   Go Up
Page created in 0.03 seconds with 16 queries.
