Pages: [1] 2 3  All   Go Down
Author Topic: Wishbone bushes  (Read 5085 times)
Martin_1962
Wishbone bushes
« on: 21 September 2009, 18:08:03 »
I need to rebush my wishbones, my buypartsbuy ones have failed after 6 months >:( >:( >:( >:(
Where do I get the solid bushes from?
Where can I get them fitted?
Tahnks
Martin
    • 530D M Sport, 330i Coupe
Re: Wishbone bushes
« Reply #1 on: 21 September 2009, 18:19:12 »
www.allgermanparts.co.uk
Meyle part number 614 035 0016 £11.00 each + P&P.
NB. You have to wait for them to put the monthly order in with Meyle Germany + a few weeks delivery though.
You'll also need a 10 tonne press and the correct drifts to fit them.
Martin_1962
Re: Wishbone bushes
« Reply #2 on: 21 September 2009, 18:40:00 »
Thanks
Well fed up now!
Have emailed buypartsbuy as well
This is so annoying only fitted them in the spring
Martin_1962
Re: Wishbone bushes
« Reply #3 on: 21 September 2009, 18:51:10 »
I remember the bottom joint was a nightmare - what tools do I need to make it easy?
THanks
Re: Wishbone bushes
« Reply #4 on: 21 September 2009, 18:52:51 »
I have not changed my wishbone bushes in 45k - According to WIM there is nothing wrong with them  ;D
Martin_1962
Re: Wishbone bushes
« Reply #5 on: 21 September 2009, 18:58:47 »
Are you volunteering? ;D
Re: Wishbone bushes
« Reply #6 on: 21 September 2009, 23:24:56 »
did you torque the bolts correctly? Wheels on the ground suspension loaded?
Martin_1962
Re: Wishbone bushes
« Reply #7 on: 21 September 2009, 23:28:00 »
Torqued yes, on ground - sort of - the bush just disintegrated.
I had the car in the air supported under the struts so was at ride height, no hope of torquing with wheels on ground.
Re: Wishbone bushes
« Reply #8 on: 21 September 2009, 23:28:49 »
Thanks
Well fed up now!
I now feel justified in digging deep & buying 'proper' Vx wishbones ...... at great expense ...... getting on for 4 yrs ago.  ::) ::) ::)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Wishbone bushes
« Reply #9 on: 21 September 2009, 23:28:59 »
Replace the front bushes with a pair of Poly-bushes. :y
Did mine the other week.
Martin_1962
Re: Wishbone bushes
« Reply #10 on: 21 September 2009, 23:31:25 »
See VXL V6 post - I will be using those
Re: Wishbone bushes
« Reply #11 on: 21 September 2009, 23:48:19 »
Due to leverage may not have been loaded enough. Also wonder if bush is designed to take load in that direction. It is a pig with a long handle t wrench though. Usable ramps next time maybe?
Bob Dent mentioned he had an early failure. Not sure if same supplier.
razzo
  • Crapital
    • 97 3.0 Elite
Re: Wishbone bushes
« Reply #12 on: 22 September 2009, 07:38:11 »
Deffo the way to go  :y
Martin_1962
Re: Wishbone bushes
« Reply #13 on: 22 September 2009, 17:56:17 »
None in for 2 to 4 weeks :(
So where do I get poly bushes from then?
Tahnks
  • Auckland
    • Mazda MPV
Re: Wishbone bushes
« Reply #14 on: 22 September 2009, 18:00:47 »
At a guess http://www.polybush.co.uk/ but I don't see Vauxhall listed on their website.
I do know that they respond to demand so it is worth contacting them to check.
Pages: [1] 2 3  All   Go Up
