Author Topic: dose any have!  (Read 1168 times)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
dose any have!
« on: 25 September 2009, 01:04:40 »
dose any one have a wiring diagram for a 2.0i 16v 1995 ecu, wires from the camshaft to crank shaft sensors and the MAF and potentiometer, as have a new sets but still engine man light on.
says 19, 21,73,92, have changed them with new ones but faults still coming up. had taken the 21 and 73 off and ran engine (ruff running) still same faults come up. tested the wires from each they all linc up with each other but the haynes book dont say much on the wires, thinking its the ECU but just need to check this out first. thanks for you help. :-/ :-/
« Last Edit: 25 September 2009, 01:06:42 by Russell_Hill »
Re: dose any have!
« Reply #1 on: 25 September 2009, 23:03:55 »
did you use pattern sensors?
rustym95
Re: dose any have!
« Reply #2 on: 25 September 2009, 23:06:51 »
origanals, every thing works when wash the engie then when it drys its all back, if u know what i mean. so think there is a dead line some were and the water is fixing it for a time.
« Last Edit: 25 September 2009, 23:07:39 by Russell_Hill »
Re: dose any have!
« Reply #3 on: 26 September 2009, 09:13:29 »
I'd be checking engine earths and battery voltages as a starter for 10.
rustym95
Re: dose any have!
« Reply #4 on: 26 September 2009, 15:00:30 »
Hi have had them off clean'd them all still the same.
