Author Topic: Common place for an oil leak  (Read 1291 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 25 September 2009, 08:47:20 »
Just noticed a dribble of engine oil on the road, is there a common place for oil leakage on the 3.2? Or could it be anything?
Thanks
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Common place for an oil leak
« Reply #1 on: 25 September 2009, 22:50:07 »
the oil filter i would think, all i seen are that at fault.
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 25 September 2009, 22:52:21 »
How old is your oil filter??
Don't think that will leak if you change it regularly.
Did you hit anything with the underside of the car (made a hole in the sump)??
« Reply #3 on: 25 September 2009, 22:57:51 »
same as other v6 's afaik. Cam covers (most likely), crank seal, oil pressure switch. When where breathers last cleaned?
Are you sure its engine oil not atf? (if auto)
« Last Edit: 25 September 2009, 22:59:20 by chrisgixer »
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 25 September 2009, 22:59:52 »
First check the top of the engine to be sure it isn't cam cover gasket.
Then check the sump, then oil pressure switch, oil filter are easily replaced but never heard of one leaking except if it wasn't placed properly :-/
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 25 September 2009, 23:01:42 »
Chris isn't this car a little to new to be leaking brake oil  (atf)already??
« Reply #6 on: 25 September 2009, 23:10:40 »
Atf = Automatic transmission fluid. (Dexron 3) less likely than engine oil imho.
Where the oil drips under the car will be biggest clue i guess.
  • Doha, Qatar
« Reply #7 on: 26 September 2009, 12:25:33 »
Thanks chaps. I had the cam cover gaskets changed recently and cleaned the breathers about a year ago. The oil was changed about six months ago. I hope it is something as simple as the oil filter not fitted correctly.
Where abouts is the oil pressure switch?
    • 530D M Sport, 330i Coupe
« Reply #8 on: 26 September 2009, 18:42:46 »
Front left, look down at the sump lip from above and you'll see it.
