Author Topic: code 74  (Read 3426 times)
Re: code 74
« Reply #15 on: 26 September 2009, 09:09:55 »
what is paperclip code 74 on a diesel, Ive only changed the alternator :( had to also trace a faulty earth wire but thats all sorted now. What else could I have done :-/
Did you start the engine with MAF disconnected? If so, may be a stored code that will go after a set number of 'clean starts'
Unfortunately, no way with paperclip to tell if its a stored code, or a current code.
I'm making an assumption that MAF is plugged in ;D - number of times I forgot to plug mine back in on my tractor, and only notice due to a very subtle difference in initial throttle response.
ali
  • hertfordshire
Re: code 74
« Reply #16 on: 26 September 2009, 09:55:02 »
I should really PM this but hey ho everyone knows Im no mechanic ;D ;D ;D ;D whats the MAF ::) ::) ::) I will search  :y :y There was something under the manifold I didnt connect but after driving around for a bit I remembered :: ;)
Re: code 74
« Reply #17 on: 26 September 2009, 10:05:13 »
Mass Air Flow.  Just noticed your TD is a 94. U25DT engines (1994 and 1995) do not have MAFs, so ignore me....
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: code 74
« Reply #18 on: 26 September 2009, 15:13:35 »
no not listning the fault code is there is to many volts coming in to the ecu, its charging to good just needs a few good runs to settel it down again then the fault code will be gone.
Incorrect I'm afraid
Well just checked with m8 at garage drove it 20miles and the ECU light is not on now volts chargng at 13.5 insted of 16.5volt. :y you need amps not volts, to meany volts lowers the amps.
« Last Edit: 26 September 2009, 15:15:50 by Russell_Hill »
ali
  • hertfordshire
Re: code 74
« Reply #19 on: 26 September 2009, 18:37:15 »
Yes SYD is an old boy, my garage told me not many left so I would like to keep him going for as long as possible ;) better body work than my 99 petrol, not sure how that works :-/
Im pleased I dont have A MAF, one less thing to go wrong :y
Re: code 74
« Reply #20 on: 26 September 2009, 23:57:58 »
The voltage regulator on the back does what it says on the tin - regulates voltage
rustym95
Re: code 74
« Reply #21 on: 27 September 2009, 01:20:47 »
Not on a recon :y
Re: code 74
« Reply #22 on: 27 September 2009, 11:46:50 »
Not on a recon :y
A voltage regulator is a voltage regulator, whether new or 2nd hand.  If it doesn't do its job, or is intermittent doing its job, its knackered  :'(
