Author Topic: Just changed my sump by torchlight in the rain!  (Read 3018 times)
« on: 03 December 2007, 17:45:32 »
Last time I did an oil change, the sump plug thread knackered on me. At the time, I Was desperate for the car, so I used a nut and bolt in the sump to keep the oil in  ::)
Since then, the oil has been getting blacker and blacker - I have constantly put it off, but I've now had to bite the bullet, because it's been 5k miles since the last oil change.
My new sump pan arrived at Vx today - so it was time to fit it.
In total, it took me about 45 mins to remove the old one, and refit the new one. Had to give the old one a little bit of a persuading off, but it wasn't too bad.
I wasn't sure of the torque for the lower sump bolts, so I made a sensible guestimate of 10nm when refitting - felt about right. I wasn't paying £40 odd for a new gasket just for a little sump pan - so I used some of the oil cooler grey sealant on it. I find that works well on sumps.
I seem to recall Mark saying that the drain plug itself only needs to be 10nm with the rubber o ring on it - so that's what it had. I will always use my torquewrench on this plug, I don't want to strip another!
(Although in fairness, the last one wasn't my fault...)
I popped a new oil filter in, and I've filled back up with oil, fired it up - job done.
I then moved the car to the other end of the road, because I didn't want any of the neighbours to see the rather large oil stains were from my car  ::) - I cleaned up as very best as I could, but you just cannot do this job without dripping some oil!
All the time, it was pitch dark, so I was working outside the house by torchlight, with the rain absolutely lashing down, meaning I was lying in a bath of cold water. So a messy, cold, frustrating job, but hey it's done.
I'm going to do a few 500 mile oil changes, to get it back to being nice and clean again...
Bath and beer now :y
miggy
Re: Just changed my sump by torchlight in the rain
« Reply #1 on: 03 December 2007, 17:47:38 »
Well done mate
 :y :y :y :y
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 03 December 2007, 17:49:11 »
Nutter !  ;D
I take my hat off to you mate - well done. By the way shouldnt this be in the general help section as its car and not nags head related  :D
« Reply #3 on: 03 December 2007, 17:51:25 »
Maria just ruffled my hair, and quickly withdrew her hand - 'cos it was covered in used engine oil. She's now tutting and wiping her hands. Quality  ;D
miggy
« Reply #4 on: 03 December 2007, 17:52:04 »
Nutter !  ;D
Did your wig stay on
 ;D ;D ;D
« Last Edit: 03 December 2007, 18:01:53 by miggy »
« Reply #5 on: 03 December 2007, 17:53:33 »
Well done for contemplating car work in this weather! Was going to clean mine this weekend ::) .. again!
Still, that oil ought to stay clean for a while on LPG?
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #6 on: 03 December 2007, 17:54:39 »
Good Job James, thats commitment for you. :y :y :y
Well done.
« Reply #7 on: 03 December 2007, 17:56:17 »
I'm sure it will - at least I'm now in a position to change it when needed, and I don't have to be so careful over speed bumps  ;D
« Reply #8 on: 03 December 2007, 17:57:16 »
Well done.
Thanks mate... I would feel a lot more committed if I had a nice warm heated garage for such jobs, with a hydraulic lift  ::)
« Last Edit: 03 December 2007, 17:57:37 by JamesV6CDX »
« Reply #9 on: 03 December 2007, 18:00:24 »
Way way above & beyond the call of duty! [smiley=vrolijk_26.gif]. Well done! :y  :y :y :y
It'll be spring before I venture under my car.  ;D
PS What kind of torch?  ;) Maglite held in your mouth or a LED headlamp?  ;D  ;D
« Last Edit: 03 December 2007, 18:02:02 by Andy_B »
« Reply #10 on: 03 December 2007, 18:06:00 »
It was a little rubber torch that looked like it came out of a cracker, and had less light than a candle. And yes, I frequently held it between my teeth  ;D
Martin_1962
« Reply #11 on: 03 December 2007, 18:17:22 »
I did an oil change and breather clean yesterday
« Reply #12 on: 03 December 2007, 18:47:10 »
You'd need a snorkel & flippers to do anything outside here today. I'd considered a job on the caravn aerial today but, ..... didn't! ::)
    • 530D M Sport, 330i Coupe
« Reply #13 on: 03 December 2007, 18:54:03 »
Must do another oil change on mine, now 3K since last change and hoping the weather will be dry on Sunday.
Miss having a garage now  :'(
Martin_1962
« Reply #14 on: 03 December 2007, 19:13:28 »
Dry but windy - the oil blew sideways half way while draining
