Author Topic: uneven engine running  (Read 1381 times)
roberthilditch
  • midlands
« on: 27 September 2009, 13:22:56 »
any ideas as to cause and its solution?
Re: uneven engine running
« Reply #1 on: 27 September 2009, 13:25:04 »
What engine? Fill in your details e.g. Car/engine/location :y
roberthilditch
  • midlands
« Reply #2 on: 27 September 2009, 13:30:18 »
MV6 3litre automatic
« Reply #3 on: 27 September 2009, 13:31:51 »
Paperclip it see if you get any fault codes.
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
roberthilditch
  • midlands
« Reply #4 on: 27 September 2009, 13:32:21 »
and the location is the midlands
« Reply #5 on: 27 September 2009, 13:34:34 »
Click on "User CP" @ top of page and "edit profile". Stick all your details in, saves being asked every time you might post with a problem ;) :)
roberthilditch
  • midlands
« Reply #6 on: 27 September 2009, 14:04:27 »
entered details tried paperclip and nothing happened
« Reply #7 on: 27 September 2009, 14:10:19 »
Have you checked plugwells for oil. Failing cam cover gaskets can cause uneven running due to oil contamination on the plugs/leads and dispack
roberthilditch
  • midlands
« Reply #8 on: 27 September 2009, 14:22:06 »
thats been checked
« Reply #9 on: 27 September 2009, 14:28:07 »
Does your EML illuminate when ignition switched on? Strange that you didn`t get at least a 31 when you `clipped it :-?
roberthilditch
  • midlands
« Reply #10 on: 27 September 2009, 15:52:45 »
you have to excuse my ignorance but what is an EML? and all that happened when i cliped it was the ignition lights came on as normal
roberthilditch
  • midlands
« Reply #11 on: 27 September 2009, 16:05:28 »
clipped it again and got 31 it must be me not doing it right
