Author Topic: TD Broken down.  (Read 3343 times)
Agemo
  • Cleethorpes
  • Insignia
TD Broken down.
« on: 27 September 2009, 13:26:49 »
I went to a car boot sale this morning, car was fine, been stopped there half an hour, went to start it, spinning over OK but would not fire. Tried locking/unlocking a few times, no joy. Tank was half full, I know I need a new pump for the tank sometime but never had a problem with at least 20 litres in the tank. drained a bit of Diesel out of the fuel filter, looked perfectly clean, no muck, no water. Undid the Banjo on top of the filter, & filled it up with Diesel. The engine coughed & spluttered into life, but then died, repeated this & it started, I nursed it to a filling station the other side of the road & filled up. This proved there was half a tank of Diesel in it. The car behaved itself all the way home, even when driven "briskly". I will be replacing the pump, but anyone suggest anything else? It points to fuel starvation, but never had any trouble before.
I fitted this filter not that long ago, I have also cleaned the filter in the tank. The Diesel has always been clean, and I have added Diesel Magic to both the tank and the filter in the past.
Oh, and you can't do the paperclip test on this model, or the pedal trick,
« Last Edit: 27 September 2009, 13:32:31 by Agemo »
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: TD Broken down.
« Reply #1 on: 27 September 2009, 14:04:48 »
When you do get to do the lift pump, it'll probably just need the muck cleaned out of the pot and off the gauze filter rather than changing the whole thing.
Did mine a few months back. One occasion recently I was down to 35 miles of fuel left on Range display and it started on the button.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: TD Broken down.
« Reply #2 on: 27 September 2009, 14:07:28 »
Start at the tank Glen:
Remove the filler cap, and listen carefully to hear if the pump runs - it should run for a short while, while it 're-charges' the fuel system. It may however sound quieter than normal due to your tank now being full.
I'm also wondering if the 'ribbed' transfer pipe (base of pump swirl pot to outlet) could be the culprit. Might be difficult to ascertain though, again due to a full tank of fuel.
Agemo
  • Cleethorpes
  • Insignia
Re: TD Broken down.
« Reply #3 on: 27 September 2009, 14:08:31 »
I have cleaned all the muck out,, it wasn't that bad though. The problem sounded like fuel starvaton, but I gave it a good blowout on the way home, and there was plenty of OOMPH for a Weasel.
« Last Edit: 27 September 2009, 14:08:57 by Agemo »
Agemo
  • Cleethorpes
  • Insignia
Re: TD Broken down.
« Reply #4 on: 27 September 2009, 14:11:22 »
I am sure the pump in the tank is either lazy, or not working. I want to replace it anyway though. I am just hoping I don't have something with an intermittant fault, a sensor or summat.
Seth
Re: TD Broken down.
« Reply #5 on: 27 September 2009, 14:13:34 »
Ah, the 'Italian Tune-up' method .......
No need to do this on mine, Mrs Sethsmate does it every time she drives it!
Note Glen: Two South Walian tractor-owners on the ball here ......
Agemo
  • Cleethorpes
  • Insignia
Re: TD Broken down.
« Reply #6 on: 27 September 2009, 14:17:34 »
Yup, a good burn up clears out all the cobwebs, although it was running fine before this morning. Yes both from The Valleys, you must own 50% of the Migs in S Wales. Just have to run "The Enemy" to ths shop, at least it will prove it's still funning fine.
« Last Edit: 27 September 2009, 14:21:19 by Agemo »
Seth
Re: TD Broken down.
« Reply #7 on: 27 September 2009, 14:19:07 »
You should be okay Glen, it's usually associated with the in-tank gubbins.
It's more than likely that filling the tank has kick-started the pump back into action. Heard of this happening before.
« Last Edit: 27 September 2009, 14:19:45 by Reliance505 »
Agemo
  • Cleethorpes
  • Insignia
Re: TD Broken down.
« Reply #8 on: 27 September 2009, 14:20:42 »
Kick starting the pump? Yes you may be right. I will be sourcing a new pump then. Thanks.
Seth
Re: TD Broken down.
« Reply #9 on: 27 September 2009, 14:23:27 »
Not visiting your sisters for dinner today mate?
Seth
Re: TD Broken down.
« Reply #10 on: 27 September 2009, 14:32:01 »
Our Turk's not quite from The Valleys, but my tractor should be able to reach his abode in around 35 minutes, subject to no hold-ups en-route.
Mrs Sethsmate'll easily clip a good 5 minutes off that though. Gotta drive it like you stole it ... !
« Last Edit: 27 September 2009, 14:33:41 by Reliance505 »
ali
  • hertfordshire
Re: TD Broken down.
« Reply #11 on: 27 September 2009, 15:23:03 »
 ;D ;D ;D ;D ;D ;D ;D  :y :y :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: TD Broken down.
« Reply #12 on: 27 September 2009, 20:57:02 »
If you have a replacement that is known to be working fine, then slap it in when you get a chance. :y
As for listening for the pump at the filler cap, not sure you'd hear anything. Couldn't on both pumps I have. They work fine, original was just well gummed up.
They have just a slight buzz when briefly connected to 12v to test before replacing. I'd say the damping effect of the diesel would make it less audible again.
Agemo
  • Cleethorpes
  • Insignia
Re: TD Broken down.
« Reply #13 on: 27 September 2009, 21:19:20 »
Thanks Turk, I will have a listen when the level goes down a bit. I should have given the pump a proper test when I cleaned the filter.  ::)
Re: TD Broken down.
« Reply #14 on: 27 September 2009, 21:56:30 »
Have you tried paperclip method, a significant proportion of TDs are paperclippable
