Author Topic: ABS & TC lights on Dash  (Read 776 times)
Botman
« on: 29 September 2009, 12:36:46 »
Hi guys, new to this forum and wondered if anyone could help. Both of the ABS & TC lights are permanently on and there is also a little bit of smoke coming out from under the bonnet! are these related? any idea of costs? or does it sound terminal.  I am just trying to avoid paying £55 for diagnostics so any help would be appreciated.
I_want_an_Omega
Re: ABS & TC lights on Dash
« Reply #1 on: 29 September 2009, 12:40:43 »
Does the speedo still work as this is fed from the ABC/TC control unit which sounds like it has failed.
Where are you located - update your members profile with some more info to see if one of the guys who does servicing is close by.
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #2 on: 29 September 2009, 12:48:55 »
If the speedo is fine it could be a faulty brake switch.
As for the smoke have you popped the bonnet to see where it comes from it could be a leaky seal
« Reply #3 on: 29 September 2009, 13:01:23 »
Forget paying. Have a read here http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #4 on: 29 September 2009, 17:06:41 »
Paper clip & pedal test only do engine fault codes.  ;)
