Author Topic: Sunroof stops after dead battery  (Read 1473 times)
w33bob
« on: 28 September 2009, 19:55:06 »
Bit of a strange one this, have a 2000 Elite which had a perfectly working sunroof until the radio was left on accidently overnight and the battery drained.
Got a set of jumpleads and started the car the next morning, everything was working fine until I tried to tilt the sunroof and it wouldn't do a thing. Checked the fuse and it's fine and the sunroof switch itself is still lit up but the sunroof is totally dead.
Anyone experienced this problem before or have any ideas?
Thanks
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Sunroof stops after dead battery
« Reply #1 on: 28 September 2009, 20:05:00 »
Try pushing the switch up and hold it in for a few seconds sounds like it has lost its memory have you checked that the windows work correctly they may need resetting two  :y
« Reply #2 on: 28 September 2009, 20:40:56 »
Thanks
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf page 125  ;)  ;)
geoff
  • thornaby,stockton on tees
« Reply #3 on: 28 September 2009, 20:48:11 »
sunroof and windows will need resetting if battery has drained it's like dissconnecting the battery no power :y :y
w33bob
« Reply #4 on: 28 September 2009, 22:29:49 »
Thanks for the advice and replies lads it's now working a treat! Was just an annoying niggle as I love the sunroof tilted rain hail or snow!
« Reply #5 on: 28 September 2009, 22:31:44 »
Thanks for the advice and replies lads it's now working a treat! .......
When all else fails ........ read the manual!  ;)  ;)  ;D  ;D  :y
« Last Edit: 28 September 2009, 22:32:07 by Andy_B »
LFF64
  • HADDENHAM BUCKS
« Reply #6 on: 28 September 2009, 23:13:59 »
Or ask on here  :y :P
markh1
  • surrey
« Reply #7 on: 29 September 2009, 09:23:24 »
I also have this problem! Glad this thread came up!
'98 Omega 3.0 Elite Manual - Slowly having most of running gear replaced
'98 TVR Cerbera 4.5 - completely rebuilt on new chassis
« Reply #8 on: 29 September 2009, 10:09:22 »
i thought the radio turned itself off after an hour?
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #9 on: 29 September 2009, 11:40:01 »
Yer mine does that . Sometime when i,m having a power nap in the car a lunch i put it one . Hour later it turns off.
« Reply #10 on: 29 September 2009, 16:51:30 »
Assuming factory fit ........  ;)  ;)  ;)
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
« Reply #11 on: 29 September 2009, 17:12:24 »
if you fit another radio, it also depends how you wire it,( i wanted mine on permenent). it will stay on forever, but lights up so i cant forget to turn off. sonys will bleep to remind you when you take the key out. if wired correctly.
oh bugger, i thought that was a bit of wind!!!
