Author Topic: Sump removal  (Read 1323 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Sump removal
« on: 29 September 2009, 15:38:20 »
Hi guys,
Anyone here removed the sump before?  I get the oil lack message alot which I think comes from the sensor in the sump so I want to get in there clean things up and clean/replace the strainer.  Looked in the maintenance guides and nothing there so firstly:
- is it a pig of a job or fairly easy?
- paper gasket or sealant for refitting?
- torque values for the sump bolts if known.
TIA :y
Guffer
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Sump removal
« Reply #1 on: 29 September 2009, 16:04:11 »
Hi guys,
TIA :y
Guffer
ask loo-knee, he did the oil pump on my old elite last week :y
Gaffers
Re: Sump removal
« Reply #2 on: 29 September 2009, 16:45:25 »
Hi guys,
TIA :y
Guffer
[SHOUT] Oi!  Bog roll! Hurry up and pitch in yer reet pink tart [/SHOUT]
Do you think that'll do it...?  ::)
Re: Sump removal
« Reply #3 on: 29 September 2009, 16:48:54 »
Hi guys,
TIA :y
Guffer
Fairly easy & straight forward to remove the lower sump pan
I was given (sold  ::)) a grey instant gasket/glue in a mini silicon sealant type tube from Vauxhall, stuck like the proverbial to a blanket.  ;)
Mr Haynes says 8 metric newton thingies/ 6 lbft and then angle tighten a further 30o
The wires to the sensor were quite brittle, I had to resolder one of them as it broke at the switch
 :y  :y  :y
« Last Edit: 29 September 2009, 16:50:21 by Andy_B »
Gaffers
Re: Sump removal
« Reply #4 on: 29 September 2009, 18:13:46 »
Hi guys,
TIA :y
Guffer
 :y  :y  :y
I havent checked the connections physically, just visually and they looked ok.  Maybe I should get the multimeter on it and wiggle some wires......
The Red Baron
Re: Sump removal
« Reply #5 on: 29 September 2009, 18:17:49 »
Hi guys,
TIA :y
Guffer
i think you need to shout louder. :D
Re: Sump removal
« Reply #6 on: 29 September 2009, 18:18:09 »
The connections INSIDE the sump.  :y There's 5" or 6" of wire between the plug at the back/top of the sump and the actual level switch.  :y
Gaffers
Re: Sump removal
« Reply #7 on: 29 September 2009, 18:36:14 »
fook mi, this is gonna get dirty... maybe I should get the wife involved ::) ::)
The Red Baron
Re: Sump removal
« Reply #8 on: 29 September 2009, 23:10:23 »
yeh, 5 or 6 inch involved here.  :P
Gaffers
Re: Sump removal
« Reply #9 on: 30 September 2009, 07:34:26 »
Now you're just being rude!  ;D ;D ::) ::)
The Red Baron
Re: Sump removal
« Reply #10 on: 30 September 2009, 07:48:18 »
:D dont know what you mean
