Author Topic: "Squealing" tyres, any suggestions ?  (Read 3621 times)
the_bed_wrecker
  • SUNNY HARTLEPOOL
  • Where's that stormtrooper gone ?
« on: 27 September 2009, 12:56:36 »
Hi all, my nearside tyre's squeeling like mad everytime I take a corner, worse on right hand turns and mass under steer.
Have changed bottom wishbones both sides, steering idler and track rod end on near side, due to pull when braking. Had the traking done and swaped the wheels round.
Feels Ok on the straight.
Is  Vauxhall Part Number: 9195731 the correct one for a 2.0 ? and any other suggestions ?
Cheers
Karl
Must be getting old to have one of these !!
RobG
    • 16 plate Mokka. Vivaro
Re: "Squealing" tyres, any suggestions ?
« Reply #1 on: 27 September 2009, 13:16:09 »
Cheers
Karl
For what :question If you mean the steering idler, yes it is. As for the tyre squealing, if you have swapped the wheels and still get the squealing i`s not going to be the tyre. Have you checked front N/S bearing. :question
« Last Edit: 27 September 2009, 13:21:56 by RobG »
« Reply #2 on: 27 September 2009, 13:20:21 »
9195731 is a steering idler arm, and they are the same throughout the range.
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 27 September 2009, 14:14:52 »
I have Winter tyres on, and they squeal more than any others.
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #4 on: 27 September 2009, 15:10:17 »
Have you the same make and model tyres on the 4 road wheels
« Reply #5 on: 27 September 2009, 16:20:16 »
Squealing issue aside for a minute, have you had the camber set correctly since changing wishbones?
Tracking on its own is a waist of time. Needs full geometry set up.
See how it is once set correctly. :-)
What tyres are they exactly?
the_bed_wrecker
  • SUNNY HARTLEPOOL
« Reply #6 on: 27 September 2009, 18:37:40 »
Hi how do you set the camber ?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #7 on: 27 September 2009, 20:16:53 »
Tony at Wheels in Motion is the man - but it's a fair old drive from Hartlepool if it's understeering.
geoff
  • thornaby,stockton on tees
« Reply #8 on: 27 September 2009, 20:21:38 »
i have the same problem but only on different types of tarmack sometimes it does some time it does not strange ehh :y
the_bed_wrecker
  • SUNNY HARTLEPOOL
« Reply #9 on: 27 September 2009, 22:58:54 »
Is there anyway of setting it up myself ? have a engineering shop at work so prob can get of any measurment tools.
Whats adjusted to get it correct ?
If its got to be a garage job any suggestions for somewhere near hartlepool.
Cheers
K
K
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #10 on: 28 September 2009, 03:22:34 »
Mine dose that found out the tyre has a default in it, had it checked at local and said it was nothing wrong, steering was fine and traking etc was ok.
Omega's is a life not just a car. also do ecu codes read and wiped or rest.., fix LCD tv & DVD recorders PS3's and most electrical equipment just e-mail me.
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #11 on: 28 September 2009, 14:34:18 »
I believe that Hi-performance in Seaham do the full geo. Mate. its a lot closer to hartlepool.
heres there tel. no give them a ring. :y
0191 5811821  :y
there also not to bad with the prices
He who brakes Looses
To old to die young
the_bed_wrecker
  • SUNNY HARTLEPOOL
« Reply #12 on: 28 September 2009, 18:38:20 »
Hi, hows the camber adjusted ?
rustym95
« Reply #13 on: 28 September 2009, 18:59:06 »
I wouls get a garage to do it as you could make it worse, should not cost more than £30 :y
the_bed_wrecker
  • SUNNY HARTLEPOOL
« Reply #14 on: 01 October 2009, 16:51:35 »
Had the camber checked and its ok, but the tracking was out, am going back to the original place to get a refund.
Problem now is back to the original one, press the brakes and the car goes left, steering goes right !!
Changed: bottom wish arms (both), idler arm, off side brake caliper, nearside track rod end.
Had it on a rolling road and brakes ballanced altough the pull only seams to show when braking hard, think it maybe the nearside caliper (as its the only thing left to change !)
Anbody out there got one to sell ? :-X
