Author Topic: Gearbox warning  (Read 1719 times)
abertawe1970
  • shropshire
Gearbox warning
« on: 04 October 2009, 19:42:20 »
I've got a 3l v6 auto vreg, on my way to work this evening the check automatic gearbox flashed up on the screen. Also the TC light came on the clock display as well, what could this be????
Re: Gearbox warning
« Reply #1 on: 04 October 2009, 20:03:50 »
Could do with getting GEARBOX codes (not engine codes).
abertawe1970
  • shropshire
Re: Gearbox warning
« Reply #2 on: 04 October 2009, 20:17:31 »
Don't want to sound stupid, But how do i do that?
Re: Gearbox warning
« Reply #3 on: 04 October 2009, 20:32:15 »
You need a code reader or someone else with a code reader to read the fault codes.  :y  :y  :y  :y No way to do it yourself like engine codes.  :(
abertawe1970
  • shropshire
Re: Gearbox warning
« Reply #4 on: 04 October 2009, 20:40:42 »
Thanks Andy  :y, looks like the garage again then.  :'(
Re: Gearbox warning
« Reply #5 on: 04 October 2009, 20:52:57 »
If you have a laptop with a serial port or access to one, you can buy what is refered to as a 'Cheapo Tech II' for less than what most garages will charge you to read various codes, and you'll have it for another time time. Mine was IIRC £25 and has read a few different types of codes & reset airbag lights a couple of times so has paid for itself a couple of times over. USB type apparently can be problematic.  :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Gearbox warning
« Reply #6 on: 04 October 2009, 21:14:46 »
Cheapos won't read the gearbox though.
TuBy's new whipping boy.
Re: Gearbox warning
« Reply #7 on: 04 October 2009, 22:07:41 »
Didn't know that.  :-/
Re: Gearbox warning
« Reply #8 on: 04 October 2009, 22:09:21 »
Unless you use MDTM's modified data file ;)
Re: Gearbox warning
« Reply #9 on: 04 October 2009, 22:10:21 »
And we can get it from ....... ?  :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Gearbox warning
« Reply #10 on: 04 October 2009, 22:15:39 »
Never had any luck even with the MDTM version myself.
"My Naff Code Reader" will do it though.
Re: Gearbox warning
« Reply #11 on: 04 October 2009, 22:17:35 »
Or for cheapo tech2s, see the FAQ about code readers, and try the demo software - much better than the rubbish they provide
