Author Topic: hot start fix on ebay  (Read 2737 times)
bellers
« on: 02 October 2009, 14:02:52 »
have done some searching on google about the warm start problem on the dervs and found this
http://cgi.ebay.co.uk/Hot-Starting-Fix-Range-Rover-BMW-Diesel-P38-DT-DSE_W0QQitemZ390100016343QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item5ad3c5dcd7&_trksid=p3286.c0.m14
anyone used one of these? do they work?
thanks
« Last Edit: 02 October 2009, 14:05:44 by bellers »
Re: hot start fix on ebay
« Reply #1 on: 02 October 2009, 14:15:00 »
I believe some of the tractor owners on here have resolved issues using it
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 02 October 2009, 14:27:17 »
I also saw a few topics here regarding that. Some claimed it helped them
bellers
« Reply #3 on: 02 October 2009, 14:29:01 »
i hope it works as its anoying and ive taken omega of the road till i get it fixed   :(
Ian_D
  • York
« Reply #4 on: 02 October 2009, 18:19:41 »
Easy to fit, will only take you a few mins to do.
Only got to tap into 4 wires iirc.  :y
[size=12]
Stevie-blunder
  • Wolverhampton
« Reply #5 on: 02 October 2009, 18:31:56 »
Spot on  :y done mine, works brill now, after fitting when warm the glow plug light will come on wait 3 or 4 seconds after it goes out and will start easy  :y :y
« Last Edit: 02 October 2009, 18:32:21 by Stevie-blunder »
KillerWatt
« Reply #6 on: 02 October 2009, 19:36:05 »
£30 for a 555 timer IC and a couple of resistors/capacitors????
Bloody hell, I should have pursued the electronics rather than settling on being a sparks.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #7 on: 02 October 2009, 19:40:46 »
But it keeps my company in business :)
KillerWatt
« Reply #8 on: 02 October 2009, 19:45:35 »
I must admit, I do like the "scare" tactic of "Others are selling a standard 5 pin relay & a single resistor"
It's complete & utter bullshit, but then anybody who pays £30 for a 20p IC will believe it anyway.
Stevie-blunder
  • Wolverhampton
« Reply #9 on: 03 October 2009, 16:48:41 »
Garage I bought my Mig from spent £400 trying to cure the hot starting problem under their warranty, I cured it for £30, consider that a RESULT  :y
ali
  • hertfordshire
« Reply #10 on: 03 October 2009, 22:08:11 »
With out it Syd would have been scrapped for parts :'( :'( :'( it maybe simple but it did the trick for me :y :y
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #11 on: 04 October 2009, 19:28:37 »
its also done the trick on mine  :y :y
Ian_D
  • York
« Reply #12 on: 05 October 2009, 19:38:30 »
End of day, 30 quid is nothing if it solves to hot start problem really is it?
20p is ‘complete & utter bullshit’ anyway!
20p for a 555, yeah maybe, but then you need to pay P+P  ;)
Caps will again be 10p each (wonder what the minimum order is? 25?)
Resistors will be a few pence each (can you buy them in quantities under 50?)
Would need a relay too, so that’s going to be 75p.
Then a little project box £1.25...
Not to mention the time to actually put all this together, and determine all the component values in the first place.
What starts off as a cheap 20p job will soon be at least 5 quid. (On a one off basis remember) Not to mention the few hours of time involved in sourcing, building, testing, packaging it!
The other problem is most people don’t have 555 timers, caps + resistors, veroboards, soldering irons laying about, and more so most people wouldn't have a clue where to do with them if they did!
« Last Edit: 05 October 2009, 19:39:47 by Ian_D »
[size=12]
