Author Topic: Brake shoe adjuster  (Read 1696 times)
DaveyDavey
Brake shoe adjuster
« on: 07 October 2009, 12:41:57 »
Afternoon all.
Does anybody know the size of the spline bit (12 point star shape) required for the rear brake shoe adjuster?
My screwdrivers don't seem capable, and I don't want to round it off, so I thought I may as well buy it even if I only use it a couple of times.
TIA  :)
Re: Brake shoe adjuster
« Reply #1 on: 07 October 2009, 12:57:02 »
Don`t think there is one :-/ and if there was, how would you get it through  the hole in the hub?
Did you not manage to get the disc/drum off?
  • Auckland
    • Mazda MPV
« Reply #2 on: 07 October 2009, 13:01:38 »
The brake shoe adjuster is a star shaped nut that you turn (one click at a time) using flat screwdriver poked through the hole provided in the rear hub. I don't think a star/torx bit will be any help for this job but I would recommend getting a set for all the other jobs on an Omega.
Rear brake maintenance guide here http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
The brake adjuster is at the top of this photo
« Reply #3 on: 07 October 2009, 13:13:34 »
I guess you mean the torx based disc retaining bolt.
DaveyDavey
« Reply #4 on: 07 October 2009, 13:18:20 »
Hmmmmmmmmm I suddenly have a feeling like I'm doing something extremely silly.  :-[
It is a distinct possibility that I am looking at the wrong star shaped thing. What I'm looking at (and will not budge an inch) seems like it will take one of these perfectly http://www.lasertools.co.uk/item.aspx?cat=278&item=1711 hence my enquiry.
Is the adjuster simply operated by the movement up/down of the screwdriver then?
« Reply #5 on: 07 October 2009, 13:23:21 »
Yes and yes :D
  • Auckland
    • Mazda MPV
« Reply #6 on: 07 October 2009, 13:24:15 »
Yes
The star shaped nut is pushed hard up against one of the retaining springs which means it clicks round with quite a bang. In this photo you have to click up to loosen the adjustment. On my last car the adjusters were in the other way round so I had to click down to loosen.
« Last Edit: 07 October 2009, 13:24:55 by andyh »
DaveyDavey
« Reply #7 on: 07 October 2009, 13:29:45 »
Yes and yes :D
Right  :o
Well if anyone needs me, I'll be in the stupid corner making a large white conical hat with a big D on it then.  :'(
« Reply #8 on: 07 October 2009, 13:31:04 »
Did you manage to remove the disc/drum Dave :)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #9 on: 07 October 2009, 14:53:58 »
it's abit rusty, for a 99, mine are still black, give it a good clean and use some copper grease.
  • Auckland
    • Mazda MPV
« Reply #10 on: 07 October 2009, 15:33:46 »
Those are pictures from the howto prepared by 'Marks DTM Calib'.
I don't think DaveyDavey has posted any photos of his adjusters.
