Author Topic: Any idea what type calliper I have?  (Read 2086 times)
SteveD
  • Blackpool (no casino)
« on: 06 October 2009, 11:13:16 »
Me being lazy here....
I'm lead to believe my V reg facelift 3.0 Elite Estate could have either Lucas or some other make(can't remember at the mo.) of calliper on the front.
Does anybody know for definite which type it will be or do I have to take a look? If the only way to tell is from looking, does anyone have a couple of pics so I can tell without removing a wheel?
Thanks
Steve
« Last Edit: 06 October 2009, 11:13:30 by SteveD »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Any idea what type calliper I have?
« Reply #1 on: 06 October 2009, 12:00:55 »
nope would think you would need to remove it as need to be the same as other side. :y
« Reply #2 on: 06 October 2009, 13:50:15 »
Thanks
Steve
Only one type of caliper ever fitted to the front of the V6's
SteveD
« Reply #3 on: 06 October 2009, 22:13:56 »
Thanks for that, are they made by Lucas?
« Reply #4 on: 06 October 2009, 22:29:26 »
Thanks
Steve
And rear calipers are wider if vented discs on the rear as well as the front??? Some body asked the other day and couldn remember for sure. :-(
Cant help with the make sorry. Dont remember much in the way of markings either tbh
steve-o2.5
  • Fort William
« Reply #5 on: 07 October 2009, 19:38:08 »
just a wild guess but i'm going to go 4 brake as opposed to leg or vernier!!!!!!!!!!!!!!!!!!!!!!!!!!! ;D ;D ;D ;D(sorry just couldn't resist)
« Reply #6 on: 07 October 2009, 21:50:28 »
Possibly, dont recall.....the only front caliper and disc setup that was different was pre 97 2.0's!
So if some factor is trying to give you the run round, tell em they dont know what they are talking about  ;D ;D
« Reply #7 on: 07 October 2009, 21:51:05 »
Thanks
Steve
Fairly obvious but, vented discs are wider than solid ones and hence require a larger caliper  :y
« Reply #8 on: 07 October 2009, 21:54:30 »
Obvious to most .... but not to all  ;). We've had 2 instances of solid discs fitted into vented calipers without it being noticed till there was a fluid leak  ;)  ;)  ;)
« Last Edit: 07 October 2009, 21:54:46 by Andy_B »
jonathanh
  • coventry
« Reply #9 on: 07 October 2009, 21:58:29 »
Front calipers:
V6 and later 4 pots are lucas
earlier 4 pot: ATE
« Reply #10 on: 08 October 2009, 00:05:32 »
Obvious? ;D  if you've ever laid eyes on non vented on an Omega, then yes i'm sure it would be!!!
