Author Topic: Help needed with engine codes  (Read 849 times)
frankfaz2000
    • 2003 2.2 Sport Saloon
« on: 12 October 2009, 14:17:43 »
I have 2.5 V6 and have recently changed plugs and rocker cover gaskets, now I have done it I am getting engine managment light on, have check codes and I am getting 1-9 incorrect RPM signal and 5-9 intake manifold 1 low voltage.
Can anyone please pointme in the direction to fix these faults, motor runs fine and very smooth.
Regards Frank
Re: Help needed with engine codes
« Reply #1 on: 12 October 2009, 14:20:36 »
19 - crank sensor - replace - it WILL let you down
59 - Rear multiram - check its plugged in
« Reply #2 on: 12 October 2009, 14:24:25 »
Yep, crank sensor fault and rear multiram which is on the rear of the plenum changer....check its plugged in (easy to miss if its your first go on these engines)
