Author Topic: now Climate fans  (Read 912 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
now Climate fans
« on: 12 October 2009, 02:12:55 »
This has happened a few times with the climate set the fans sometimes do not start when the system is in auto but if its taken off auto the fans work ok through the range .
 But put it back in auto they stop again no matter what the temp is set at
I found that after a few engine off on s the system all kicks back in ok
 I did try to reset  the climate but this does not help you can hear the servos all doing something after its reset .Any ideas  :question
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: now Climate fans
« Reply #1 on: 12 October 2009, 08:19:02 »
would this be something to do with the sampler fan needing to be cleaned out.
« Reply #2 on: 12 October 2009, 11:44:55 »
Next time you pass, pop it in, and we'll see what the ecu thinks is going on.
Worth doing the 'tissue test' over sampling fan, as that makes the climate confuse itself if its failed, but unconvinced thats your issue.
LFF64
  • HADDENHAM BUCKS
« Reply #3 on: 12 October 2009, 17:48:45 »
I  may have to take you up on that if it keeps doing it
« Reply #4 on: 12 October 2009, 17:58:33 »
Feel free - most evenings but tonight. Unsure of weekends yet
