Author Topic: fault code - on 1998 2.0i 16V  (Read 1130 times)
marcus
« on: 12 October 2009, 21:03:11 »
Still trying to sort out intermittent misfire - next step replace fuel filter but on doing paperclip test to check out engine mgt faults I get the following result, which I cannot find in any fault code list.
ignition on, engine not running code 10-3
ignition on, engine running - no fault codes showing
any ideas?
« Last Edit: 12 October 2009, 21:04:05 by m26 »
Re: fault code - on 1998 2.0i 16V
« Reply #1 on: 12 October 2009, 21:09:29 »
Try it again and write down the sequence of flashes then post up
marcus
« Reply #2 on: 12 October 2009, 21:14:37 »
yes this is the sequence in sets of 3 with the engine stopped i.e 10,3 then 10,3 then 10,3 and then start again
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #3 on: 12 October 2009, 22:32:12 »
