Author Topic: door adjustment  (Read 1511 times)
geoff
  • thornaby,stockton on tees
door adjustment
« on: 13 October 2009, 10:31:08 »
is it possible to adjust door gaps for forward and back or up and down can't see any adjustment if i can :y :y :y
Re: door adjustment
« Reply #1 on: 13 October 2009, 10:32:13 »
Forward and back, no, up and down, to some extent yes by adjusting the catch plate on the B or C pillar's.
Do check the hinge pins for wear though
geoff
Re: door adjustment
« Reply #2 on: 13 October 2009, 10:35:41 »
ok just seeems my drivers door seems further forward than the passenger side could this be normal or pin wear  :y :y :y
unlucky alf
  • worksop, notts
Re: door adjustment
« Reply #3 on: 13 October 2009, 10:39:32 »
is that on the door shut side or the front edge?, might be the front wing thats too far back :y
geoff
Re: door adjustment
« Reply #4 on: 13 October 2009, 10:40:25 »
door shut side :y :y
unlucky alf
  • worksop, notts
Re: door adjustment
« Reply #5 on: 13 October 2009, 10:42:48 »
sounds like the hinges have taken a whack in the past, is there any sign that its a replacement door. :-/
geoff
Re: door adjustment
« Reply #6 on: 13 October 2009, 10:45:58 »
when brother in law bought car 5 years ago was cat c but garage only replaced wing
unlucky alf
  • worksop, notts
Re: door adjustment
« Reply #7 on: 13 October 2009, 10:57:31 »
might be worth trying to take some measurements, i had this on a car some time ago & found it was the hinge sections on the post were bent,  :y
