Author Topic: Wishbone/polybush torque values.  (Read 1652 times)
Boatboy
  • St Albans
« on: 12 October 2009, 12:15:57 »
Are the torque/angle values the same whether using poly bushes or standard? Got some powerflex to fit and don't want to knacker them through ignorance or assumption.
Thanks in advance,
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
Re: Wishbone/polybush torque values.
« Reply #1 on: 13 October 2009, 00:30:02 »
hmmm, good question. Would presume the same as genuine, but assumption is the mother of all ***k ups, as you say. Anyone?
 I beleive Turk and Razzo have fitted polly if they dont pop in you could PM them? Hth
« Last Edit: 13 October 2009, 12:47:48 by chrisgixer »
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #2 on: 13 October 2009, 08:13:39 »
Thanks in advance,
Steve
Yes Steve, i set it all up as per mantainance guides & have had on problems. Car sailed through mot testerday with no advisories for the second year running  :y
I mentioned the car was poly bushed & they are going to offer this to customers as failed wishbone bushes were quite common  :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #3 on: 13 October 2009, 19:23:33 »
Yep, standard spec here too  :y
Boatboy
  • St Albans
« Reply #4 on: 14 October 2009, 07:58:44 »
Thanks for the confirmation guys.
Turk, I took heed of your video how-to and changed the bushes without removing the wishbone although I had to do it in the road.
Not keen on using a blow torch down there I used a power drill with 6mm bit to completely 'muller' the rubber before removing the central core and then cutting through the sleeves with a standard hacksaw.
Steve
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #5 on: 14 October 2009, 14:08:23 »
Well done matey :y
Don't think your partner/mother/neighbours/council (or anyone else that tend to complain about the least thing) would be too happy with the mess made by the rubber if you'd used a blow torch either.
You'll need to get check your tracking asap. Mine was well out after fitting the poly's.
Ideally a full geometric  :y
