Author Topic: engine back pressure problem  (Read 1026 times)
cazcar
« on: 15 October 2009, 16:34:54 »
2.5 v6 auto omega with back pressure problem , checked breather system all clear does anyone know any other causes as this one has burst a couple of hoses at front of engine , the car is a 95 reg.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: engine back pressure problem
« Reply #1 on: 15 October 2009, 16:38:44 »
Could be your cats mate, when you look at the front of the engine there is a silver/chrome pipe running horizontally to a rubber hose just infront of the Air Con Pump, this pipe blows when Cats are blocked as a rule ;)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 15 October 2009, 17:00:24 »
There's another one at the other end of the pipe on the drivers side of the engine.
As Daz says if these are blowing out it usually points to a blockage in the exhaust system.
TuBy's new whipping boy.
  • Auckland
    • Mazda MPV
« Reply #3 on: 15 October 2009, 17:03:57 »
There was a thread on here by someone who found that one of the non-return valves had failed in one of the stainless air injection pipes that bolt onto the exhaust manifolds.
I imagine that would cause hot exhaust gases to pressurise the FAI pipes without there being a fault with the CATS.
Page created in 0.015 seconds with 14 queries.
