Author Topic: fault code help on traction control  (Read 6201 times)
nick v6
  • walsall / west midlands
« on: 08 October 2009, 19:26:12 »
after the garage wrecked my mig doing the mot and i changed the abs unit to get the light to go out i still had the TC light staying on
i have put my diagnostic machine onto the car to see if it just needs clearing and it keeps coming back on
ive saved the fault code to my laptop and this is what i get
"My Naff Code Reader" 080805 - PC based diagnostic tool
"My Naff Code Reader" - KW82 Communication Window> 1994|Omega-B|Chassis|ABS-2SE (+TC)
KW82 protocol initialized.
ECU ID= XD,90447588,0273004049,BB27355, 4,
Total number of fault codes: 1
00071 - Transmission Ratio
Present
any ideas anyone
Re: fault code help on traction control
« Reply #1 on: 08 October 2009, 20:37:24 »
Sorry Nick  :(  :( No idea!
nick v6
« Reply #2 on: 08 October 2009, 20:39:37 »
no probs mate
im going to try a live run so that the diagnostic can test rolling speeds
i think 1 of the sensors have been knocked :(
« Reply #3 on: 08 October 2009, 20:59:09 »
can't think why for MOT but anything on the gearbox? Was the engine running when you did the test?
nick v6
« Reply #4 on: 08 October 2009, 21:01:23 »
ive done it with engine running and with just the ignition on both say the same
« Reply #5 on: 08 October 2009, 21:04:56 »
That code suggests transmission / ratio problem with is separate to the ABS / TC.
I would check all the leccy connectors are plugged in ok on the box
nick v6
« Reply #6 on: 08 October 2009, 21:07:33 »
yeah im going to check that tomorrow :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #7 on: 08 October 2009, 21:10:09 »
With your car being a manual my guess would be that the abs ecu is off an auto and hence is complaining about the lack of signal from the auto box (which the car doesn't have).
Hence the abs ecu needs a chat with a tech2 to set the variant code correctly.
TuBy's new whipping boy.
nick v6
« Reply #8 on: 08 October 2009, 21:12:19 »
when i got the abs unit me and the seller made sure all the part numbers and the code on the yellow sticker on the unit was the same
  • Auckland
    • Mazda MPV
« Reply #9 on: 08 October 2009, 21:14:15 »
How does it work out the ratio? Does it compare road speed with engine rpm? If the ABS/TC was reporting a fault would the gearbox store a fault as a consequence?
Maybe the fault will clear once the box has had a chance to work through all the gears with a working ABS/TC ecu.
« Reply #10 on: 08 October 2009, 21:19:17 »
i would have thought from the diff, as that knows how fast/slow each axle is spinning.
« Reply #11 on: 08 October 2009, 21:20:03 »
unless an ABS sensor is fubared and thus giving a false signal on how the axles are rotating.
nick v6
« Reply #12 on: 08 October 2009, 21:27:04 »
i can do a live reading while driving which is what ill do while im taking the kids to school in the morning :y
« Reply #13 on: 08 October 2009, 21:28:27 »
I'd assume the TC works by comparing the speed of the none driven front wheels with the speed of the rear driven wheels. If they both accelerate at the same rate then the rear wheels are gripping ie not spinning. If the rear(s) are accelerating faster than the fronts, then the TC needs to do something.   :-/  :y
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #14 on: 08 October 2009, 22:32:04 »
would check for a rogue wire, from spec a boom cannot upset the sensors lol  :y
