Author Topic: Hard Brake Pedal  (Read 1653 times)
Big Bri
  • Swansea
  • WELSH AND PROUD!
Hard Brake Pedal
« on: 14 October 2009, 22:57:27 »
My brake pedal is hard most of the time, I have replaced the vaccuum pipes and the one way valve but the problem is still there although there is plenty of vacuum, when I press the pedal lightly it does sink a bit but if I press hard it doesn't sink at all, could this mean that the servo is at fault, or is it possible that it is something else.
Thanks.
« Last Edit: 14 October 2009, 23:10:58 by bigbri »
Omega Elite 3.0 V6 24V Manual
[img name=signat_img_resize]http://i262.photobucket.com/albums/ii103/bloosemore/dadsig-1.jpg[/IMG]
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Hard Brake Pedal
« Reply #1 on: 15 October 2009, 00:40:34 »
do you know when the brake fluid was last changed, or what colour is it. may just need new fluid, full flush out. :y
Big Bri
  • Swansea
  • WELSH AND PROUD!
« Reply #2 on: 15 October 2009, 17:28:26 »
Thanks for the reply the brake fluid was changed less than a year ago. :y
« Last Edit: 15 October 2009, 17:47:29 by bigbri »
  • Auckland
    • Mazda MPV
« Reply #3 on: 15 October 2009, 17:51:46 »
It does sound as though the servo is at fault. Split diaphragm maybe? or perhaps the gubbins inside that controls the air/vacuum has seized.
I won't insult your intelligence by asking if the new vacuum non return valve is in back to front. ;)
Big Bri
  • Swansea
  • WELSH AND PROUD!
« Reply #4 on: 15 October 2009, 18:10:40 »
;D  ;D  haha yes its on the right way :y
« Reply #5 on: 15 October 2009, 23:24:40 »
Try pumping the pedal half a dozen times with the engine stopped then, with moderate pressure on the pedal, start the engine. You should feel the pedal drop a little. Then turn the engine off and pump the pedal a couple of times. You should get assistance for 3 or 4 pumps of the pedal before it goes hard again.
If assistance is not working then it's vacuum supply to the servo or a fault in the servo itself. If you can feel the servo working then look for siezed caliper pistons, crushed brake lines or perhaps seriously glazed friction surfaces. :-/
Big Bri
  • Swansea
  • WELSH AND PROUD!
« Reply #6 on: 16 October 2009, 19:00:06 »
Thanks for your reply, I have solved the problem now, it seemed that one of the smaller pipes coming off the one way valve must have been leaking.
