Author Topic: Heater fan not working.  (Read 1047 times)
belldarr
« on: 16 October 2009, 21:59:32 »
My heater fan appears to have packed up, checked the big 30A fuse and that appears ok so suspect it's the actual fan behind the dash - are these easy to replace or is there some other stuff I should check first?
Symptoms are just a few noises of what sounds like liqiud circulating behind the panel (matrix?) and no fan noise at all when I press the fan increase button, the display shows the fan getting faster but nothing is coming out.
Any help much appreciated, as ever.
Darren
Re: Heater fan not working.
« Reply #1 on: 16 October 2009, 22:39:51 »
Check the relays in engine compartment
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
« Last Edit: 16 October 2009, 22:42:32 by RobG »
belldarr
« Reply #2 on: 17 October 2009, 13:38:45 »
Thanks Rob, can anyone tell me how to reset the climate control from the panel, may as well try this while I am messing around with it.
Darren
Welung666
« Reply #3 on: 17 October 2009, 21:36:43 »
Darren
With the climate on press and hold the OFF and AUTO buttons for a few seconds (5 is normal) until you hear the servos running then let go. They'll settle down after 3 or 4 seconds :y
