Author Topic: back end sliding advice needed  (Read 3616 times)
mathewst
  • Split, Croatia
    • v40
« on: 17 October 2009, 15:07:07 »
My back end started sliding heavily today.
This happens when I turn right, left turn isn't the issue it seems.
And the biggest problem I'm out of the country  and should journey back home today evening.
What is the possible cause of this (shocks, springs etc...?
Please help!!!!
Re: back end sliding advice needed
« Reply #1 on: 17 October 2009, 15:08:49 »
expand more on 'sliding' loosing grip?
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 17 October 2009, 15:12:36 »
When turning right my back end went twice out of control and started sliding in the oposite lane ( left lane, cause I'm in europe) And I was driving slowly
« Reply #3 on: 17 October 2009, 15:15:42 »
sounds rather drastic, your tyres are not bald are they?  ;D
Assuming you don't have an LSD? (never seen one fitted to a 4pot)
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 17 October 2009, 15:18:00 »
Tyres are 6 months old and pretty good. When I press the car (back end) it wobbles up and down a bit.
LSD, if you mean air susspension no I dont have it
« Reply #5 on: 17 October 2009, 15:20:17 »
LSD = Limited Slip Diff
Do this as a test, with the car parked up push down once firmly at each rear corner. How many 'bounces' does it do before it stops and returns to normal? It should be instant. If not your shocks are worn. Check for any leaking fluid around the top of the shocks too.
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 17 October 2009, 15:23:54 »
It does bounce up and down maybe two or three times but only slightly. I've looked at them but there seem to be no leaks visible
« Reply #7 on: 17 October 2009, 15:25:03 »
It should return straight away, sounds like they are worn, but they should not cause the rear to slide away unless you reallying putting your foot down.
belldarr
« Reply #8 on: 17 October 2009, 15:25:48 »
Bit of a long shot but just check you don't have brake fluid leaking from the rear brake, it would drip onto the wheel then spread all over the place very quickly on the affected side.
Does it wheelspin when your setting off??
Darren
mathewst
  • Split, Croatia
    • v40
« Reply #9 on: 17 October 2009, 15:26:23 »
No I didn't put my foot down even once and that is why I'm worried.
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #10 on: 17 October 2009, 16:36:14 »
Have you looked at your stabi joints?
could be that one of them are knackered causing it to go more than it should.
as Tunnie said sound also like your shocks are fuba,
a mix from both and you drift more round corners instead of driving.
He who brakes Looses
To old to die young
mathewst
  • Split, Croatia
    • v40
« Reply #11 on: 17 October 2009, 19:37:00 »
Stabi joints??
Could you be a little more specific, or describe it what are those?
Or pic would be the best help.
Thanks
Ghost
    • 2.6 V6 CDX Estate
« Reply #12 on: 18 October 2009, 10:02:03 »
there is a bar that goes from one side to the other,
it is held in place by two rubber Brackets.
On the end of that Bar you will find another smaller bar that goes to the rear wishbone (Drop link)
it could be possible that the rubber is perrished on these.
check that there is no play, movement there.
Stabi = stabiliser = anti roll bar
To old to die young
mathewst
  • Split, Croatia
    • v40
« Reply #13 on: 18 October 2009, 12:44:57 »
Thanks for the advice Ghost.
I managed to get home from abroad last night but had to drive like an old blind lady ;D
I will check what you said.
I also have one theory, but would like an opinio o itIs it possible that one of the front spring is broken (front shocks are ok) and in combination with lousy rear shocks to cause the car to slide (back end) easily?
« Reply #14 on: 18 October 2009, 12:53:16 »
Check the springs as well, they are a known failure on Omega's  One of the rings making up the coil may have snapped at one end.
