Author Topic: Std Fit Alarm Help Please  (Read 821 times)
ScifiGuru
« on: 18 October 2009, 23:59:19 »
Hi All,
well i've finally taken the plunge and bought a 2001 2.6 CDX Estate which i'm picking up tomorrow
but i'de appreciate any help you can give on the standard alarm/immobiliser that is fitted.
I have been on a couple of websites to get an insurance quote and one seems to say the unit
is THATCHAM cat 1 approved but the other does not ? so as I don't want to invalidate my insurance
does anyone know whether it is approved or not ? especially as it's alot cheaper with the Thatcham
alarm selected.
Thanks for any advice
Re: Std Fit Alarm Help Please
« Reply #1 on: 19 October 2009, 10:46:22 »
IIRC The only Vauxhall systems that are Cat 1 approved are the ones fitted from late 98 onwards and Cat 2 from May 94 onwards :y
« Reply #2 on: 19 October 2009, 16:28:31 »
All you need to do is state or tick the box that says factory fitted alarm & immobiliser ...... it's up to them then.  :y :y
ScifiGuru
« Reply #3 on: 20 October 2009, 11:58:17 »
Hi,
Thanks for the advice,
Well after all that when the guy brought the car over and I
had a full check through a number of faults showed up which
he was 'unaware' off ??  :-?, including the alarm sounder not
working, driver's door lock intermittantly working with KEY !!
and tracking being off. So I decided not to buy in the end  :'(
Anyway back to the drawing board....
« Last Edit: 20 October 2009, 11:59:06 by scifinut »
« Reply #4 on: 20 October 2009, 12:04:15 »
Alarm, easy fix. Door lock, probably sticky solenoid, again easy fix. Tracking, at most probably wishbones and a full geometry set-up. Couple of hundred quid at most
