Author Topic: STARTING ISSUE  (Read 898 times)
ANDYM172
STARTING ISSUE
« on: 20 October 2009, 13:37:05 »
I recently changed the oil cooler on my 2000 2,6 v6 now i am having starting issues if i drive 2 miles turn it off leave it 10 mins it starts ok same after about 7 miles but after 10 miles if i leave it for 10 mins it turns over put wont fire up.  then after about half hour it starts perfect (engine management light goes out after ignition as normal)
deviator
  • Chesterfield
Re: STARTING ISSUE
« Reply #1 on: 20 October 2009, 13:58:15 »
I've heard of problems like this before.
When it doesn't start, spray the crank sensor with a hose pipe. I know this sounds stupid. But if it starts afterwards, then you need a new sensor.
For this to work, there should be no recorded error codes as well. If there are error codes then it might be a different problem.
Re: STARTING ISSUE
« Reply #2 on: 20 October 2009, 16:09:08 »
do a pedal trick, sounds like crank sensor is failing.
Page created in 0.025 seconds with 16 queries.
