Author Topic: 4 pot cam sensor fitting help  (Read 1141 times)
« on: 20 October 2009, 18:47:30 »
Hi everyone, I would appreciate any help with tips, howto, for removing/renewing a cam sensor on my 2.2i CDX. Many thanks. Phil. :y
Re: 4 pot cam sensor fitting help
« Reply #1 on: 20 October 2009, 18:49:11 »
Cam cover off (couple of bolts) move cable tray out of the way, remove black plastic "Ecotec" cover, sensor held with one bolt :y
Welung666
« Reply #2 on: 20 October 2009, 19:27:27 »
Which is in between the cam sprockets so Aux belt and timing belt cover need to come off. Oh yes it's a male T30 bolt and only needs loosening. Leave the cam sensor plugged in until it is out as it's easier to pull it out with the cable ;) :y
« Reply #3 on: 20 October 2009, 19:36:15 »
Thanks guys, and especially to you Lee, :y I can't wait to get it fitted so my other half stops giving me earache about the bloody emissions light! ::) ;D :y
« Reply #4 on: 20 October 2009, 19:55:44 »
No need on the 2.2, the black ecotec strip is the only thing that needs to be removed
Welung666
« Reply #5 on: 20 October 2009, 20:06:59 »
I think he meant 'cam belt' cover Tun, the 2.2 I've just broken doesn't have (well didn't  ::) ) have a hole in the cover, might be worth checking though Phil. The cable tray over the top of the cam belt cover has 2 x 10mm nuts, take them off and the cable tray pulls off and up a bit. Check for a hole in the cam belt cover.
« Reply #6 on: 20 October 2009, 20:15:40 »
ahh sorry yes, my mistake  :y
