Author Topic: Which water pipe would this be?  (Read 1205 times)
holtender
  • Suffolk
    • 2.5 CDX Facelift
« on: 22 October 2009, 20:17:40 »
I was trying to work out which water pipe was causing the problems and does it really need an engine out job to fix it?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150381723195
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: Which water pipe would this be?
« Reply #1 on: 22 October 2009, 20:23:35 »
could go cheap and maybe worth pulling it apart for spares ????
« Reply #2 on: 22 October 2009, 20:27:52 »
what ever pipe is failed its never £300 to fix. Only if its a heater matrix, but that does not take water to the back of the engine.
Easy option - HBV - cheapo fix and its back on the road
Slightly harder option - Coolant Bridge, easy to strip down that far, get part of a breaker, again real easy fix
« Reply #3 on: 22 October 2009, 20:33:07 »
what ever pipe is failed its never £300 to fix.  .....
It'll be the large stainless pipe I saw MarksDTM remove from Craig's car ....... I couldn't really tell you where it runs from to cos I've never had need to know on my car - somewhwere from the passenger side to the driver's via the front of the block.  ::) It's the labour rate that's going to bump the price up ..... £300 is still probably too much though.
  • Auckland
    • Mazda MPV
« Reply #4 on: 22 October 2009, 21:29:54 »
From the back of the block (possibly from the well that the oil cooler sits in) it bends round and runs over the drivers side exhaust manifold. The radiator bottom hose connects to the front of it. One of the 3 hoses to the expansion tank comes off the top of it.
Being good quality stainless steel it is the one part of the Omega that is least likely to corrode and it is hard as nails.
I cannot remember whether it uses a gasket or on 'O' ring at the back of the block but that seal is the only part of it I can imagine causing trouble.
« Reply #5 on: 22 October 2009, 22:28:49 »
Being hard then means it's capable of cracking.  :y  :y  ;)
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #6 on: 22 October 2009, 22:43:13 »
how could the mechanic see if it was cracked?
I would tip on the hbv.
He who brakes Looses
To old to die young
« Reply #7 on: 23 October 2009, 09:04:03 »
Coolant escaping ......  ::)  ::)
« Reply #8 on: 23 October 2009, 09:31:50 »
HBC or the helterskelter coolant pipe split.....its not going to be that bloody great big pipe!
Even if it was, your only talking a 2ish hour job to change
