Author Topic: Key Blades...  (Read 1336 times)
Taxi_Driver
Re: Key Blades...
« Reply #1 on: 08 December 2007, 21:34:22 »
Not convinced it will Tunnie.........
I think the blade on the 2nd link is for non flip keys.
Best to wait until the fob arrives.......then you can see what sort of blade you need.....but i suspect the base of the blade on the flip fob will be bigger.....
Unless anyone knows  :-/
Re: Key Blades...
« Reply #2 on: 08 December 2007, 21:40:01 »
That what i thought, it looks a bit odd. Not quite right for the fob.
Also out of interest Omega key fobs, if you press and hold the close button with windows open, they will go up.
Can the Astra fob close button be re-programmed to pop the boot on facelifts, if the close button is held? - Long shot! But worth a question.
« Last Edit: 08 December 2007, 21:41:05 by tunnie »
Taxi_Driver
Re: Key Blades...
« Reply #3 on: 08 December 2007, 22:14:48 »
You live right next door to the man that knows  ::)
But i suspect no........
Re: Key Blades...
« Reply #4 on: 09 December 2007, 11:40:17 »
no
Re: Key Blades...
« Reply #5 on: 09 December 2007, 12:46:39 »
what about the blade, would that fit?
