Author Topic: Mechanical Aptitude Test....  (Read 4034 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Humbugs...
Re:  Mechanical Aptitude Test....
« Reply #1 on: 08 December 2007, 22:53:45 »
Here's mine
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 08 December 2007, 22:54:03 »
Beat you.
TuBy's new whipping boy.
speakingclock
  • North Wales
« Reply #3 on: 08 December 2007, 23:04:30 »
Same as me Cheers.
Tony
LPG Open Mixer System Tow Bar Mini Spots
Martin_1962
« Reply #4 on: 08 December 2007, 23:07:10 »
98% and I think it is the last one or the venturi one.
I said atmospheric pressure on the last which it actually is
Venturi I guessed
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #5 on: 08 December 2007, 23:08:44 »
OK, I got 430 points at 86%.
I don't know how to post a screen shot though. Still a pass is a pass I suppose.  :y
[size=24]        [/size][/b]
The Cambelt Kid
  • Derby
« Reply #6 on: 08 December 2007, 23:11:14 »
nur nur nur nur nur
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
« Reply #7 on: 08 December 2007, 23:13:16 »
hi,
press ctrl-printscreen together
open paint and from the menu choose paste..then with the upper leftmost cutting tools "quadrilateral" cut
open a new file paste again and save..Then upload in photobucket..click the image tag ...
and paste in reply in OOF screen
« Last Edit: 08 December 2007, 23:13:43 by cem_devecioglu »
« Reply #8 on: 08 December 2007, 23:22:57 »
errm..How is that  ;D ;D
Golfbuddy
  • Cornwall
« Reply #9 on: 08 December 2007, 23:25:57 »
hi,
Cheers, too late now, I closed the window and I'm not going through that again. Good to know for next time though. I never thought about using 'paint'.  :y
MartinP
  • Dudley
    • BMW 320D
« Reply #10 on: 09 December 2007, 00:18:12 »
Just took this test, scrapped through!  ::)
Markjay
  • London
« Reply #11 on: 09 December 2007, 00:40:18 »
Venturi I guessed
You can review the test, and the atmospheric pressure is the correct answer so it must be the venturi... which incidentally i got wrong.
Alas, no more Omegas....
« Reply #12 on: 09 December 2007, 08:46:25 »
100%....there are a few trick ones....the combustion engine is one of them!
Th venturi is a classic one that people get wrong....if you think of a carb, the pressure in the venturi is less hence why it draws the fuel in......so the level will be lower
sir moanalot
  • fens
« Reply #13 on: 09 December 2007, 09:58:30 »
88% i remembered something from the spanners!
Tab
  • Telford
« Reply #14 on: 09 December 2007, 10:42:18 »
oh dear, i got 68% ;D ;D
