Author Topic: Autobox Oil cooler...  (Read 2045 times)
Ian_D
  • York
« on: 16 October 2009, 15:31:11 »
Seen these on ebay quite often. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170263840818
What models were they fitted to? My Gearbox oil cooler is inside the radiator, which I assumed was the norm?
Is there any advantages /disadvantages to an external oil cooler?
Reason I’m asking is my mig is starting to run on the hot side (radiator is blocked – found out when I put the caravan on the back a few weeks back! :-[). I noticed that the gearbox oil cooler must block 50% of the radiator inlet/outlet at least? Surely that cant be good for the water flow?  :-?
Would I be better fitting a new radiator without the internal oil cooler, and an external gearbox oil cooler?
[size=12]
Re: Autobox Oil cooler...
« Reply #1 on: 16 October 2009, 16:34:40 »
2.6 / 3.2s have a separate cooler in front of the rad.
TBH, if you're having cooling problems that weren't there before the fault is not a fundamental design issue like this so a decent replacement radiator is all you need.
I would say any increase in efficiency of the radiator would be balanced by a decrease due to the oil cooler in front of it.
« Reply #2 on: 16 October 2009, 16:35:15 »
Watch out for failed water pumps on the TD as well. :y
Ian_D
  • York
« Reply #3 on: 17 October 2009, 00:49:48 »
Aye, forgot to say, its on the Petrol V6. :y
Been there done that with the TD - 1st day of ownership infact! Pump fell to bits on the way home... 100+ miles away too on the M6 :'(
Had to pull trousers down at the roadside and join The AA :( Thank god I had my debit card with me! :o
[size=12]
Ian_D
  • York
« Reply #4 on: 17 October 2009, 00:54:50 »
If the external oil cooler is on the newer 2.6 + 3.2's does that not suggest that the latter is the better improved option?
Either way, I need a new radiator...
Now do I go genuine GM or get one from ebay / motor factors?  :-/
[size=12]
« Reply #5 on: 17 October 2009, 10:46:28 »
Oil cooler, on other marques i've seen, not unknown to block, meaning new rad. Seperate cooler easier to change/flush.... possibly? Either way dont think there is a cooling issue to worry about tbh.
omegadan67
  • northampton
« Reply #6 on: 17 October 2009, 15:46:27 »
am i right in assuming that certain omegas (td's i think)  had a seperate oil cooler in one of the front wings!!!!!!
I seem to recall a friend got hold of one from a scrapped omega and fitted it to his 3.0 petrol to aid gearbox oil cooling while towing think they are fitted in the drivers wheel arch i shall try get hold of him and ask
A little infomation is dangerous in the wrong hands
Ian_D
  • York
« Reply #7 on: 25 October 2009, 21:07:50 »
Dont know, I guess hes referring to the intercooler though  :y
[size=12]
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #8 on: 26 October 2009, 08:00:56 »
ian if you find that you need any new transmission fluid i may have some. gen gm too.  :y
