Author Topic: Whats could be wrong now? :(  (Read 2704 times)
portomega
  • Port Talbot, S. Wales
« on: 26 October 2009, 12:50:48 »
just been on a quick run to the shops, car started fine, parked, did what i needed then got back in, went to start car, EML stayed on, idle sat at around 1200-1400, then put it in D and no revs, well i think it had gone into "limp mode" could drive it but wouldnt do more than 15-20 mph  :-/......any idea whats up with it now? after around 5 restarts the EML stayed off and it would drive like normal.....its a 2.2 so no pedal trick for codes, and no where local i can get a code reading but could anyone make a rough guess of what could cause this problem? :'(
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: Whats could be wrong now? :(
« Reply #1 on: 26 October 2009, 12:52:17 »
had the same prob on a vectra sri turned out to be the maf
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 26 October 2009, 12:57:05 »
do paper clip test, would think it cam sensor or crank sensor. but do test first :y
« Reply #3 on: 26 October 2009, 13:03:04 »
It's a 2.2 and as the OP says they can't be paper clipped!  :y  :y
portomega
« Reply #4 on: 26 October 2009, 13:04:00 »
mines a 2004 2.2 petrol so none of the tricks...pedal or paperclip..... work on it :(
i was just reading on a seprate post about someone with an EML on and in a reply someone mentioned something about a blowing exhuast could be a cause? is that right? because mine has a slight blow from the centre section  :-/
rustym95
« Reply #5 on: 26 October 2009, 13:09:35 »
only quoting as some have done it well say they have done it in forms.
« Reply #6 on: 26 October 2009, 14:01:18 »
You might be able to pedal test a 2.2.
However, it sounds to me like a problem with the drive by wire throttle. Need the fault codes from the ECU to confirm, but might be worth checking the connector on the throttle body hasn't become loose.
portomega
« Reply #7 on: 26 October 2009, 14:08:13 »
had a look around the engine nothing looks like it disconnected, ive been out and started it a few times now and it seems to start and drive as normal, when it went into "limp" mode the engine cooling fans were spinning like crazy, the engine wasnt overheating but it was hot, just above 90, could that have anything to do with a problem?.....hoping this was just a one off glitch
davethediver
  • Blackburn, Lancs.
« Reply #8 on: 26 October 2009, 15:20:36 »
Hi there had same thing on mine a few weeks back and it turned out to be the cam sensor, changed that and all ok now.
But as said best to get codes read :y
P.A. Caron de Beaumarchais
« Reply #9 on: 26 October 2009, 15:33:10 »
Very early 2.2's can be pedal tested, but no 2.2 can ever be paper clipped
portomega
« Reply #10 on: 26 October 2009, 15:55:24 »
Hard to get codes read here in sunny Wales, cam sensor? i always panic when the word "sensor" is mentioned  :o
mathewst
  • Split, Croatia
    • v40
« Reply #11 on: 26 October 2009, 16:08:51 »
I would bet on cam sensor on it's way out.
It's around 60 pounds and you can use only the original one aftermarkets don't work trust me.
How much miles has the car done?
« Reply #12 on: 26 October 2009, 16:10:04 »
from your description sounds like cam sensor (i had exactly the same symptoms) Don't worry its a cheap easy fix, but replace with a GM sensor!
portomega
« Reply #13 on: 26 October 2009, 17:14:06 »
the car is just coming upto 88,000miles. So if i had to replace these sensors i should only get the genuine ones from Vauxhall? another thing i noticed when i had this problem earlier, when i actually turned the car off again, instead of just stopping dead the engine would sort of splutter twice then stopped ( this is after id turned the igniion off)
« Reply #14 on: 26 October 2009, 17:20:56 »
Yes only get from Vx, its easy to replace. Aux belt off. Black eco strip off, cam belt cover off, tiny bolt between the cams
