Author Topic: car conked out  (Read 3639 times)
dopey
car conked out
« on: 25 October 2009, 17:59:26 »
Hi guys
New here and could do with some 2nd opinions if you have the time.
Approx 3 months ago I got the heater bypass valve changed.
Pretty much instantly the car developed a wicked miss-fire, sounded like a traction engine with a bunch of spanners lobbed in.
The miss-fire has remained but is inconsistent - it is generally there on start up but then usually clears after a few miles/mins.
Then the other day I was in the fast lane of the M1 and the engine just died.  Electrics and everything else fine, starter motor fine etc.
Long story short - it starts when its cooled down, but is now rougher than a rough thing.
Reading other posts it looks to be crank sensor, so I did pedal test which seems to concur.  However, it also kicked up a 560-system voltage and 230-fuel pump circuit error.
Just wanted to check if crank shaft sensor could have caused all of these issues or if maybe the ECU is playing up etc
Any advice would be V helpful
Re: car conked out
« Reply #1 on: 25 October 2009, 18:02:12 »
HBV has nothing to do with engine firing. Assuming the garage did the work? Do you know if they messed around with the HT leads?
« Last Edit: 25 October 2009, 18:02:31 by tunnie »
pedroMV6
  • York
  • Der Metzgermeister
Re: car conked out
« Reply #2 on: 25 October 2009, 18:04:11 »
HBV - near the dispack, innit?
Knocked a lead or the 12V cable?
dopey
Re: car conked out
« Reply #3 on: 25 October 2009, 18:08:21 »
They accessed the HBV by taking the top part of the engine off (plenum?)  the 4 leads out of the back of it were dotted up with numbers on the case and leads, so looks like they matched everything up.
Apologies for the lack of knowledge on the engine setup - fine on bikes but this V6 is a different kettle of fish.
Re: car conked out
« Reply #4 on: 25 October 2009, 18:21:19 »
the fact this just started as soon as the HBV was changed suggests the garage messed up the order of the HT leads
dopey
Re: car conked out
« Reply #5 on: 25 October 2009, 18:24:21 »
If the ht leads were in the wrong order, would the car not be running rough all of the time rather than just initially?
Re: car conked out
« Reply #6 on: 25 October 2009, 18:26:09 »
They might not have pushed it home all the way?
Crank sensor would cause the car to die on the motorway, then start later. Normally i would say crank, but the fact this started as soon as the HBV was changed makes me think the garage did something.
Do a pedal test to get the codes
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: car conked out
« Reply #7 on: 25 October 2009, 18:28:28 »
Think I'd be changing the crank sensor if it's showing up a fault code then see how it is.
The pedal test may be showing some old codes that have since cleared but are still stored in the ecu.
TuBy's new whipping boy.
dopey
Re: car conked out
« Reply #8 on: 25 October 2009, 18:29:51 »
I got 335 - crank sensor, 560 - system voltage and 230 fuel pump.
So suggests crank sensor - but agree with you that timing of the problem seems a bit of a coincidence.  Plus not sure what the other codes mean in idiot-speak and whether they are related or not.
The nice AA chap ran the codes stored at the time and they were general misfire codes, so he cleared them out.  The 3 codes above have cropped up in following the last start up attempt after the codes were cleared.
« Last Edit: 25 October 2009, 18:31:45 by dopey »
Re: car conked out
« Reply #9 on: 25 October 2009, 18:31:37 »
crank sensor is a code 19, double check those codes again....
But your right get the crank sensor changed, but i think there maybe other issues here as well.
dopey
Re: car conked out
« Reply #10 on: 25 October 2009, 18:36:44 »
Was using the codes taken from
http://www.omegaowners.com/forum/YaBB.pl?num=1220619694
Should I be using different codes?  Its a 2001 2.6 V6.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: car conked out
« Reply #11 on: 25 October 2009, 18:37:52 »
Err just a point chaps, how many plug leads does a 2.6 have?
dopey
Re: car conked out
« Reply #12 on: 25 October 2009, 18:41:52 »
Thumbing through haynes manual as I type - dont think those 4 leads are actually the plug leads.
As I say - apologies for lack of grasp of V6.  Trying to get up to speed with it, though Haynes don't make it easy!!
Re: car conked out
« Reply #13 on: 25 October 2009, 18:43:31 »
Good point  ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: car conked out
« Reply #14 on: 25 October 2009, 18:44:39 »
Good point  ;D
;D ;D They tend to be a bit light on dis packs too.
