Author Topic: 2.2 -02 won't start  (Read 1411 times)
Magenta
  • Finland
2.2 -02 won't start
« on: 22 October 2009, 08:27:33 »
Hello
Rotates fine.
Spark present.
Sparkplugs dry.
Fuelrail has gaspressure present.
No trouble codes.
What is wrong ?
Why won't injectors work ?
M
« Last Edit: 22 October 2009, 08:37:39 by magenta »
Finland
Re: 2.2 -02 won't start
« Reply #1 on: 22 October 2009, 08:30:06 »
Do you have access to code reading equipment (guessing by word 'sedan' in profile that you're not UK based?)
Cam sensor is a common fault, but normally the car will start eventually.  I would not change parts without getting ECU codes read first
Magenta
  • Finland
« Reply #2 on: 22 October 2009, 08:48:33 »
No Trouble codes present.
How to test camshaft sensor ?
Now I am getting + in the midle,
left 12,4 ohm, right 8,5 ohm
looking from the front of the car.
Is this intact or broken ?
M
« Last Edit: 22 October 2009, 08:53:14 by magenta »
Finland
« Reply #3 on: 22 October 2009, 09:02:43 »
M
cam sensor will show up on code reader if faulty.
Engine management light comes on with ign? Doesn't flash at any point?
« Reply #4 on: 22 October 2009, 09:09:55 »
double check the transponder is still in the key!
Otherwise cam sensor is the only sensor that will stop a 2.2 from starting.
« Reply #5 on: 22 October 2009, 09:11:51 »
Really? I think there is an awful lot that could stop it ;)
« Reply #6 on: 22 October 2009, 09:14:39 »
crank sensor unplugged it will still start..
Run like a bag of spanners with a lot of stuff off, but to actually stop it starting not a lot  :-/
« Last Edit: 22 October 2009, 09:14:48 by tunnie »
Magenta
  • Finland
« Reply #7 on: 22 October 2009, 10:00:30 »
Hello
What does it mean In key ?
A sign with spaner over car coms on with ign.
Unfortunatelly all lights and meters flas
due to lack of power.
When should it flash ?
What does it mean ?
M
« Last Edit: 22 October 2009, 10:05:51 by magenta »
Finland
« Reply #8 on: 22 October 2009, 10:02:08 »
Hello
M
Inside car key (remote), there is a tiny little transponder, it talks to the imoblisor, and without it, the car will just crank away but not start because the imbolisor is still engaged.
If you have never taken it apart, then not to worry it should be there  :y
« Last Edit: 22 October 2009, 10:02:29 by tunnie »
Magenta
  • Finland
« Reply #9 on: 22 October 2009, 10:09:26 »
Hi
Transponder is in plase and tryed to clean it.
Neither of 2 sets of keys work.
Does this imobilaiser cut of fuel
or how does it work ?
M
Finland
Magenta
  • Finland
« Reply #10 on: 28 October 2009, 07:59:42 »
Hi
Actually started bangig the key to stering wheel
so it broke in 2.
Used the botom, with the transponder
and the car started...
Still wondering if the reason was
the key or ECT...
Mika
Finland
MickAP
  • South Derbyshire
« Reply #11 on: 28 October 2009, 11:44:19 »
Hi
so it broke in 2.
the key or ECT...
Mika
A bit drastic >:( but if it worked :y
Mick
