Author Topic: unkown vibration  (Read 7124 times)
madmv6
  • kent
unkown vibration
« on: 26 October 2009, 11:19:54 »
Hi I have got an omega mv6 3.0 saloon pre-facelift and it has a bad vibration above 70mph that shakes the entire car and does not go away, I have had new wheels and tyres balanced and fitted, new discs and pads all round and this has not helped. I was wondering what else would cause this.
Any help would be appreciated.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: unkown vibration
« Reply #1 on: 26 October 2009, 12:31:10 »
check you rubber prop shaft see if it still good, it can cause that problem at speed. :y
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #2 on: 26 October 2009, 12:37:37 »
Is the vibration comming from the front or the rear?
Have you had a look at all the rubber joints both front and rear?
He who brakes Looses
To old to die young
madmv6
  • kent
« Reply #3 on: 26 October 2009, 13:00:17 »
im not sure were its coming from because it make the whole car vibrate but i have had a look and the front prop mount and it looks new, but i didnt no if the prop is meant to have any weights on it because i cant see any.
rustym95
« Reply #4 on: 26 October 2009, 13:06:13 »
it would be the one with the universal joint or rubber round it, push it up and down if has a lot of play then may be going, also can find out if it that drive at 25-30mph and put in 5gear if it starts then its a good sign its going. :y
I_want_an_Omega
« Reply #5 on: 26 October 2009, 13:15:22 »
Get it into a high street chain for a free safety check ,,,,,,
Just make sure thy SHOW YOU whats wrong so that you can make a value judgement about what to do about it.
madmv6
  • kent
« Reply #6 on: 26 October 2009, 16:49:43 »
i have just taken the car out and at 25mph put it in 5th and it doesnt vibrate, and all rubbers look in pretty good condition.
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
« Reply #7 on: 26 October 2009, 16:52:11 »
are all the wheels sat on the hubs correctly ??? wishbones ok/ droplinks and so on
madmv6
  • kent
« Reply #8 on: 26 October 2009, 16:58:23 »
i have changed all of the wheels with a spare set and it didnt make any difference, i think they are on the hubs ok, all off the wishbones are ok but im not that sure what a drop link is
ENFIELD_MV6
  • Enfield
madmv6
  • kent
« Reply #10 on: 26 October 2009, 17:05:29 »
yep i have checked them and the front passenger one has a split gaitor but looks ok
ENFIELD_MV6
  • Enfield
ENFIELD_MV6
  • Enfield
« Reply #12 on: 26 October 2009, 17:06:45 »
there should be no play as such in them but they do have small ball joints inside which wear and can give roughly the symptoms you have
madmv6
  • kent
« Reply #13 on: 26 October 2009, 17:10:15 »
ok mate thanks i will have a look tomorrow, im also gonna check all of the bolts on the prop shaft to see if the might be loose
cheers for your help
ENFIELD_MV6
  • Enfield
« Reply #14 on: 26 October 2009, 18:04:12 »
not a problem matey glad to help were i can
