Author Topic: pipe on h.b.v  (Read 1435 times)
ajn
  • cardiff
pipe on h.b.v
« on: 27 October 2009, 19:21:47 »
hello ive replaced the heater bypass valve today but cant see where the thin pipe on top of the h.b.v is ment to go any ideas cheers ajn
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: pipe on h.b.v
« Reply #1 on: 27 October 2009, 19:30:20 »
do you mean the little vac pipe ontop of the valve? this comes from the bulkhead near where the matrix pipes go through, thin black pipe with a rubber elbow that goes on the top of the valve. :y
Welung666
Re: pipe on h.b.v
« Reply #2 on: 27 October 2009, 19:30:27 »
At the HBV end or the other end?
ajn
  • cardiff
Re: pipe on h.b.v
« Reply #3 on: 27 October 2009, 20:01:57 »
thanks for the replys ive got a rubber elbow off the hbv and about 4 inch thin pipe nothing on the end and cant see where it goes
The Red Baron
Re: pipe on h.b.v
« Reply #4 on: 27 October 2009, 20:08:03 »
if i remember right, this should plug into the bulkhead between the matrix pipes. should be a rubber connector there. ::)
ajn
  • cardiff
Re: pipe on h.b.v
« Reply #5 on: 27 October 2009, 20:16:55 »
ok thanks lads ill have a look tommorow not an enjoyable job the hbv :y
The Red Baron
Re: pipe on h.b.v
« Reply #6 on: 27 October 2009, 20:53:38 »
not really, plenty of finger cutting & swearing :D
Re: pipe on h.b.v
« Reply #7 on: 27 October 2009, 21:19:32 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204 :y
ajn
  • cardiff
Re: pipe on h.b.v
« Reply #8 on: 29 October 2009, 15:24:30 »
:ysorted thanks for all replys ajn
The Red Baron
Re: pipe on h.b.v
« Reply #9 on: 29 October 2009, 17:13:10 »
well done :y
