Author Topic: key fobs  (Read 2087 times)
goats milk
  • herford, germany
key fobs
« on: 25 October 2009, 15:43:18 »
i have a facelift omega with a two button key fob, is there anyway of changing this so it is a three button with the flip out key?
Re: key fobs
« Reply #1 on: 25 October 2009, 15:50:58 »
nope, the later keys from AstraH and new Insignia are completely different, and cannot be coded to the Omega
goats milk
  • herford, germany
Re: key fobs
« Reply #2 on: 27 October 2009, 13:53:19 »
well thats just rubbish. only vauxhall wouldnt have parts that are interchangable
Re: key fobs
« Reply #3 on: 27 October 2009, 14:05:12 »
It's even worse. There are several different types just for an Omega before you consider other models.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: key fobs
« Reply #4 on: 27 October 2009, 14:05:56 »
Buy a new car then you can have a fippy fob but it won't be a mig :D ;D
goats milk
  • herford, germany
Re: key fobs
« Reply #5 on: 27 October 2009, 17:35:12 »
i have a passat with the flippie out key anyhow, so its not all bad.
joshwyatt
  • Oxford
Re: key fobs
« Reply #6 on: 27 October 2009, 17:37:22 »
If you've only got a two button key, I assume yours is an estate then? If so then a three button fob would be of no use as the extra button is to remotely open the boot on saloon cars.
Re: key fobs
« Reply #7 on: 27 October 2009, 17:45:11 »
How much time do you have?  ;)  ;)  ;)
http://www.yellowdawg.co.uk/flipkey/Untitled-1.html
goats milk
  • herford, germany
Re: key fobs
« Reply #8 on: 27 October 2009, 17:45:33 »
thats why id thought id ask cause i was wondering if i could fit a electric boot opener to it, poss from a accord.
Re: key fobs
« Reply #9 on: 27 October 2009, 18:44:59 »
lol - the VAG flip out key must be nearly the same size as most non flip keys, and is massive when flipped!
Re: key fobs
« Reply #10 on: 27 October 2009, 18:49:08 »
The Passat we had as a courtesy car, just used the fob bit in the dash, no key blade required. I wondr what that costs to replace?  :-?
Martin_1962
Re: key fobs
« Reply #11 on: 27 October 2009, 20:34:32 »
2 types of two button squarish and at least 3 designs of two button.
You can have two button insides fitted inside a flip fob, but it is a lot of work.
Martin_1962
Re: key fobs
« Reply #12 on: 27 October 2009, 20:37:49 »
Takes about a week to do properly including glue drying times.
MUST use slow setting epoxy - I have done 4 so far
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
Re: key fobs
« Reply #13 on: 29 October 2009, 17:50:00 »
I think we've gone of subject on this one, the question is, can you use a three button key fob from a saloon omega with the third button which open's the boot release on a estate omega if you also fitted the boot release motor
