Author Topic: Mass Air Flow Sensor Voltage High  (Read 1878 times)
Kate
  • Cornwall
    • Drives people mad
« on: 27 October 2009, 16:41:47 »
Hi. I did the paper clip test and got error 74 Mass Air Flow Sensor Voltage High.
Does this mean that I need to change the MAF sensor or could it be something else at fault?
Thanks for any advice! :-* :-* :-*
Bent valve
Re: Mass Air Flow Sensor Voltage High
« Reply #1 on: 27 October 2009, 17:37:43 »
Try cleaning the Maf connector first with electrical contact cleaner.  if this dosent work the easiest thing to do is change the MAF. If you dont have a spare one to try, and you dont want to fork out for a new one, You could try removing the MAF and spraying the sensor with electrical contact cleaner, but this always seems to be a short term fix.
Kate
  • Cornwall
    • Drives people mad
« Reply #2 on: 27 October 2009, 18:19:52 »
Thanks Mick. Would a MAF from a 2.5 fit?
I_want_an_Omega
« Reply #3 on: 27 October 2009, 18:26:10 »
Good idea, I dont see that it would do any harm and is easy enough to get to to swap out.
Just make sure there is no risk the fan could start whilst working on it - probably best to disconnect the battery
Kate
  • Cornwall
    • Drives people mad
« Reply #4 on: 27 October 2009, 18:30:21 »
Yes I thought I could test the part off my 2.5 rather than replace a part that's not kaputt!
I_want_an_Omega
« Reply #5 on: 27 October 2009, 18:33:59 »
I thought thast where you were going.
If it transpires to be the culprit then I have a spare one (for a 2.5) which could be available at a reasonable price.
Did you make any more progress on the sat-nav mystery?
Kate
  • Cornwall
    • Drives people mad
« Reply #6 on: 27 October 2009, 18:38:09 »
I'm still a bit confused about the sat nav.  The only bit I seem to have is the screen! ;D
Bent valve
« Reply #7 on: 27 October 2009, 18:39:11 »
It should be the same. early ones had a different connector though, check yours is the same before you remove it.
« Reply #8 on: 27 October 2009, 18:40:32 »
Maf faults could be an air leak.  Also, it you have a 19 code, that tends to throw erroneous 74s.
The MAFs on the V6 are generally very reliable, though seen a handful now that have genuinely failed (still seen more that have been misdiagnosed as MAF fault)
Kate
  • Cornwall
    • Drives people mad
« Reply #9 on: 27 October 2009, 18:40:58 »
OK, will do.
Kate
  • Cornwall
    • Drives people mad
« Reply #10 on: 27 October 2009, 18:50:28 »
Nothing is ever simple on a mig is it! ;D
Welung666
« Reply #11 on: 27 October 2009, 18:52:01 »
Only the drivers ;D ;D
« Reply #12 on: 27 October 2009, 22:49:26 »
Kate I had same problem of stalling as you.  Usually cleaning MAF not succesful - clean contacts first or swap. I got one off ebay for just over £30 and problem solved!! Won't say I told you so - http://www.omegaowners.com/forum/YaBB.pl?num=1256470369;quote=11
Kate
  • Cornwall
    • Drives people mad
« Reply #13 on: 29 October 2009, 18:57:05 »
Seems like it is sorted now. Thanks everyone, brilliant as usual! :-* :-* :-* :-* :-* :-*
Page created in 0.039 seconds with 20 queries.
