Author Topic: Handbrake issue  (Read 3216 times)
Re: Handbrake issue
« Reply #15 on: 30 October 2009, 20:38:48 »
how bad is the corrosion?
clean em up and grease em.....wont look corroded then ;)
tyre....gonna need replacing whatever.
ABS....could be several things....the easiest of which is the bulb
SnakePliskin
  • Anglesey
  • OMEGA MV6 Estate Manual Owner
Re: Handbrake issue
« Reply #16 on: 30 October 2009, 21:08:21 »
Apparently they are pretty bad
Just found 2 tyres 245/45/17's with 5mm of tread for £20 the pair! Is it okay to have wider on the back then the front?
Could it be an ABS speed sensor as the speedo is tempramental?
Love VX's always Have
blue_dream
  • Wellingborough
Re: Handbrake issue
« Reply #17 on: 30 October 2009, 22:57:39 »
Hi mate
            just had mine moted today but mine failed on emissions yeh the exhurst had a hole in it and also the same rear brake pipes, these are easy to do clamp the flex pipe then make up the short brake lines replace bleed the caliper, my problem is the cost to replace the bloody exhurst.... £350!!! :'( :'(
Varche
  • middle of Andalucia
    • Golf Estate
Re: Handbrake issue
« Reply #18 on: 31 October 2009, 13:07:50 »
[/color]
That sounds as though it could be your ABS ECU a common problem with cars circa 98. What year is yours?  Do a search on the forum for ABS,speedo,heavy steering. You don't necessarily get all those and it isn't always the ECU. If it is the ECU there is a how to guide.
V
