Author Topic: Cambelt Tensioner Failure 10k early?  (Read 5729 times)
Re: Cambelt Tensioner Failure 10k early?
« Reply #15 on: 30 October 2009, 10:50:33 »
Not quite as memorable for James  ::)  ;D
Yes Feb '07, had trouble remembing myself. I was more than happy with your work James, it transformed the sound and feel of the engine, that old belt could have been used as a bungee.
Only thing i can think is that the tensioner is giving up, sadly with this noise it has done around 20 miles.  :'(
On the upside it pulled fine, revved fine, no loss of power, but i think its on its last legs.
I'll take cambelt cover off tommorow, but i am not sure what i am looking for  :-/
« Reply #16 on: 30 October 2009, 10:51:12 »
When did we do this belt - Feb 07 wasn't it?
Yep. My first cam belt party. That's when you two got intimate on TheBoy's kitchen floor. Thought it'd be more memorable? :-X
Ah that brings back nightmares memories i've not been able to sleep properly since ;D ;D
« Reply #17 on: 30 October 2009, 10:51:17 »
Noise still there with auxbelt off, the tensioner has no power, so that should not spin with engine on?
Yes water pump replaced, i noticed orginal had metal blades, new one had plastic  >:(
I guess pop the belt off, and visually examine tensioner  :-/
Guess so  :-/
You about tommorow?
In morning I should be. She has a Costco/Hobbycraft/Argos/Asda trip planned for me in the afternoon  :'(
« Reply #18 on: 30 October 2009, 10:52:52 »
Cool - it rings of a faulty component, to me...
If you wanna get a new kit / pump, tunnie, I'll come and pop it on for you.  :y
« Reply #19 on: 30 October 2009, 11:35:00 »
Cheers James, tempted to have a bash myself i really should learn.
Should Add that the sound is not rev related, this morning, giving it a few revs actually made the sound disappear  :-/
« Reply #20 on: 30 October 2009, 11:37:44 »
get camcover off tonight, and investigate.  I seem to recall a noise on yours before due to rubbing (or was it your dads?)
« Reply #21 on: 30 October 2009, 11:50:00 »
Father tunnies, rear plate to the cam, i think was not bolted to the back plate i think!
« Reply #22 on: 30 October 2009, 12:01:07 »
Yeah, sounds familiar now.
Check yours for similar...
« Reply #23 on: 30 October 2009, 12:39:36 »
Yes,
When we did father tunnie's, I someone forgot to put a bolt back in the backplate  ::)
Get the cover off mate, let us know what you see  :y
« Reply #24 on: 30 October 2009, 13:50:13 »
will do  :y  :)
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #25 on: 30 October 2009, 21:59:06 »
I had a similar noise from same area on mine and put in some bars stop leak (which apparently lubricates the water pump for 2 quid) and a thousand miles on no more noise. You could try this.
« Reply #26 on: 30 October 2009, 22:01:44 »
not as bad as 39,995 miles too early  :'( :'( :'(
« Reply #27 on: 30 October 2009, 22:12:00 »
Sorry Jimbob am i missing something? You had an early failure?  :-/
« Reply #28 on: 30 October 2009, 22:12:15 »
Noise is too high up to be water pump
« Reply #29 on: 30 October 2009, 22:16:56 »
Yup, Mark did my head gaskets....new cambelt kit.....
it didnt survive the test drive.
let go at low speed turning into Mark's road.
bye bye new heads  :'(
Pages: 1 [2] 3 4  All   Go Up
