Author Topic: Engine RPM signal  (Read 2239 times)
mattn
Engine RPM signal
« on: 02 November 2009, 17:09:40 »
Hi folks, own a 91 2.0l omega estate (petrol). Always started first time until now, engine management light came on and although it runs fine when driving, starting it has become a pain. Fault code says i have a prob with the engine RPM signal (rev counter is fine if that matters?) Any info about where its located, how to fix it or indeed why it's messing with my ignition would be gratefully received. hope i've given enough info. Thank you people!
Re: Engine RPM signal
« Reply #1 on: 02 November 2009, 17:16:57 »
91 Omega? Your location does not say where you are but i am betting Europe?
In '91 the Omega here in the UK was badged a Carlton.
mattn
« Reply #2 on: 02 November 2009, 17:30:01 »
It came over from Ireland apparently and has a private plate. My chum says its a 91 but im not smart enough to know how to check.
Dave Elite
  • Ellesmere Port
« Reply #3 on: 02 November 2009, 17:38:48 »
Do an ebay search for vauxhall carlton and see if it looks like them.
« Reply #4 on: 02 November 2009, 17:44:14 »
does it look like this?
or this?
mattn
« Reply #5 on: 02 November 2009, 17:56:30 »
Yep same as the top pic except for the amount it's worth!
« Reply #6 on: 02 November 2009, 17:57:19 »
crank sensor up behind a/c compressor. 'fiddly' is the word I'd use if you have a/c
Dave Elite
  • Ellesmere Port
« Reply #7 on: 02 November 2009, 18:32:55 »
Cant be a 91 then
mattn
« Reply #8 on: 02 November 2009, 18:58:40 »
So replace my crank sensor and job done? No a/c so im foolishly hoping this will be simple enough. Thanks for your help.
« Reply #9 on: 02 November 2009, 19:02:30 »
Ah, much easier without a/c
