Author Topic: rear ride hight  (Read 2183 times)
rickspeed
rear ride hight
« on: 02 November 2009, 20:23:31 »
hi replaced  rear shocks today now the back end is 3/4in lower, can it be adjusted
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: rear ride hight
« Reply #1 on: 02 November 2009, 20:34:08 »
what did you change, make or model, :-/
rickspeed
Re: rear ride hight
« Reply #2 on: 02 November 2009, 20:36:18 »
2.6 estate replaysed just the rear shocks has self leveling
rustym95
Re: rear ride hight
« Reply #3 on: 02 November 2009, 20:42:05 »
is it pump assisted, if so have you bled the systerm and reset.?
rickspeed
Re: rear ride hight
« Reply #4 on: 02 November 2009, 20:46:00 »
yes pump assisted,how do i bleed them and reset it cheers
rustym95
Re: rear ride hight
« Reply #5 on: 02 November 2009, 21:00:20 »
at hand i dont know there is a thred on hear, somthing about a bleed valve looks like a tyer valve, push it in to release the air in there and using a compresser pump it back up to ride hight and check the lever on the suspension is clean'd up and working, should be rest then.
rickspeed
Re: rear ride hight
« Reply #6 on: 02 November 2009, 21:05:13 »
could not find a valve my other miggy had one in the boot, this one the pipe runs to the front of the car will have another look in morning cheers 4 ur help :)
Re: rear ride hight
« Reply #7 on: 02 November 2009, 21:07:49 »
Nothing to do or bleed.....it should be automatic.
It might be that your old shocks were buggered resulting in to low a ride height.
You can teak it by bending the actuator arm on the level sensor. This is positioned on the drivers side (UK) rear trailing arm close to the diff.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: rear ride hight
« Reply #8 on: 02 November 2009, 21:30:42 »
Isn't ride height is determined by springs ?
Have you correctly installed the rubbers at the top of the shocks ?
« Last Edit: 02 November 2009, 21:32:17 by Turk »
Re: rear ride hight
« Reply #9 on: 02 November 2009, 21:36:23 »
determined by springs and shocks.
Re: rear ride hight
« Reply #10 on: 02 November 2009, 21:37:51 »
are the shocks plugged in?
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: rear ride hight
« Reply #11 on: 02 November 2009, 21:47:23 »
Not sure about the air assisted, but ride height of standard set up is determined by springs.
I've recently fitted a pair of custom made up-rated, standard ride height front springs and the manufacturers needed a standard sample spring and measurements off the car to get the ride height correct.
Re: rear ride hight
« Reply #12 on: 02 November 2009, 21:52:23 »
Not totaly correct actualy, the MV6 is lowered by the shocks on the rear pre 99
Re: rear ride hight
« Reply #13 on: 02 November 2009, 21:53:34 »
shocks also play a part, even with none self levellers.  Prefacelift MV6 are lowered on shocks alone for example...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: rear ride hight
« Reply #14 on: 02 November 2009, 22:12:02 »
:-? I don't get it. Just doesn't make sense. For that to lower the car the shocks would need to have no upward/extending movement at all.
With std springs the shocks would have to be shorter than std and at their maximum extention.
Page created in 0.012 seconds with 14 queries.
